Illinois
Finally got around to installing the CV Fab intercooler. Drove around for about 30 minutes doing some errands and then wanted to look at the Draggy results. I finally broke into the 4 second 0-60 time on my 25!
Combatvet
Had Vanish PPF installed on the headlights, but it didn't take to well on the edges, back to the installer.
texas
I got the turbos, injectors and HPFP installed. Currently working on logs for the 93 tune. Old injectors out.jpg DS turbo out.jpg stage 3 injectors.jpg stage 3 injectors 2.jpg DS crp stg 5.jpg all set to start.jpg
Polizi212
Installed my rear side window flag decals:
and my new Thermal tips:
I have the same Flag decal on my Silver ST!
Jessup, MD, USA
It wasn't today, but I got the Whoosh downpipes installed a week ago by a shop. I attempted it myself, but was extremely unmotivated.
It pairs well with the 3" thermal. It's pretty loud at anything over 20% throttle, but still very quiet when cruising. I now have an intermittent squeak at the rear driver's side of the Thermal that I am working on fixing.
Louisiana
Installed new tires last week.
Went with Atturo 285/40 R21 AZ850s on the stock wheels. No issues whatsoever through 1kish miles. Haven't really pushed them, but they've been fine.
Need to data log my rev1 tune from ZFG and get that finished up. Just about done messing with it at that point. Will probably add a diff brace later this summer, but that's about it until the tires need to get swapped again. Going to look at new wheels at that point.
Illinois
Did this 2 weeks ago but wanted to share. PPF full front, pillars and front section of roof, ceramic coating body and wheels, added black McGard lug nuts and tinted the windshield 70% and front windows 45%. I think I am going to have my tinter drop the front windows to 35% though.
SoCal
25 ST
Just did the first oil change on my 25 at 650 miles to clear out any break in debris. I used the extraction method and knocked it out in 15 minutes with little effort or mess. Total cost was $47.96 for 6qts of Pennzoil Ultra Platinum 5w-30 and Ford Motorcraft Filter FL-2062-A.
Maryville Tn
2023 Ford Explorer St
Over the weekend I did the GT350 brake swap, tinted windows and wheel spacers all around. 1.25" front. 1.5" rear.
Hull, GA, USA
What pads and rotors did you use?
