Install Rear Camera Washer
i8iridium
I decided to tackle the rear camera washer project today. This isn't going to be a detailed instructions down to the nut and bolt, but hopefully the pictures will help with that.
It's 4 parts:
LB5Z-17603-G - $9.60
LB5Z-17A605-AC - $13.79
LB5Z-17A605-E - $13.18
LB5Z-17A605-W - $16.59
Start by removing the plastic from the inside of the lift gate. Next you'll have to remove the spoiler. In my opinion, this was the worst part. There's three bolts, and about 8 clips.
You have to remove the pinch sensor and move it aside, then you can release the circled clip for the lower part of the spoiler.
This is the Y tube that you'll replace the stock one with as shown below.
The tube clipped into the brake light mount will connect to the next tube below.
The clips were already in place on the existing harness, so just line those up and snap it in. The tube was facing the wrong direction initially, I just had to spin it around and it connected right up. Didn't take A pic of this tubes package. It part number is LB5Z-17A605-W.
Next you'll remove the rear trim with the camera. There's six bolts on the outside of the vehicle with a handful of clips. It's a little easier to release the clips from inside the lift gate. Not much easier. lol
Behind the trim, you'll see a blank plug. Pull that out and you'll install the next hose.
Connect that to the tube inside. I forgot to take a picture of that part, but it's fairly self-explanatory.
Next you'll remove the camera from the rear trim to install the sprayer nozzle.
Just pay attention to how the nozzle blank insert comes off and put the nozzle on the same way. Be careful with the connectors.Connect up that tube and put the trim back on, and that's it. Hopefully I covered everything.
Taxgod4u
Just flew past you
2023 Exploder-ST
Thanks for he photos and part numbers!
Chamorro85
Illinois, USA
Wow, nice write-up. Pardon the naivete...did your '23 not have this or was it a 'shortage' issue that you're fixing?
I
i8iridium
My 2023 ST, and all others lost this "feature".
Taxgod4u
Just flew past you
2023 Exploder-ST
Not on my '23 either
Columbus, MT, USA
I'm pretty sure my 22 doesn't have it. Does it spray when using the rear window washer?
I
i8iridium
It might have been a mid-year change for the '22s. I don't remember for sure. Yes, it sprays with the rear washer.
Jeppo
Davidson County, NC
Anybody added the front camera washer after the delete?
I
i8iridium
I did it right after this one. There's a thread already out there.
I Bleed Ford Blue
23 Rapid Red Explorer ST
At this point someone has figured out the rear camera washer, the front washer, hands free liftgate, rear climate controls, and the front climate control display. The only other option that was deleted because of the chip shortage that hasn't been figured out is the massage seats, and that is going to be the expensive one.
Dram789
California
2020 explorer st
Damn, I didn’t know they lost this feature in the recent years. My 2020 st has front and rear
RTM
Richmond, VA
When I tried to do it in my 22 ST, purchased May 2022, it wouldn't work even though the wiper went back and forth a few times. After researching more on here, it turns out the car has to be in reverse. Once in reverse, the washer fluid flows.. Who would think it needed to be in reverse? It should work in park...
I
i8iridium
Thread Starter #13
It works in any gear. It takes a loooong time to prime the system. After that, it shouldn't take quite as long because there's several check valves in the line to keep the fluid primed.
wessideg
Minnesota
2024 Explorer XLT
It's 4 parts:
Thanks so much! I missed this feature in my 2024, using oem components will make me feel a bit less guilty about hacking into the plumbing
Silent Hit
Maine
Actually they deleted the Wi-Fi Hotspot on the '23 ST as well, they give you a $20 credit, modem and everything still there just not the router. The dealerships do not even have a part listed to replace it. I have been thinking of pulling one from a previous year but would not know how you would get it activated with ATT as they go by the vehicle VIN to activate it. I miss that in my '22 because it was unlimited for only $200 per year! If anyone has figured this out let us know. I have installed a Netgear Pro M6 with an antenna in my car with ATT, they offer true unlimited at 50Mbps at $90/month under a business plan. If you need it that is an option, if you use your phone hotspot you burn through your allotment quickly and they slow you down.
Jbellef
Colbert, WA
Where did you get all of your parts from, I have tried a few different places with no joy. I found out after I had bought mine that there was just a plug instead of the washer itself. That really ticked me off. I will attempt to install during nicer weather if I could achieve the parts.
Tasca parts. Just ordered it up myself using the part numbers from the first post.
EDIT: It looks like LB5Z-17603-G has a new revision LB5Z-17603-J. Will need to confirm when the part comes in.
