Trans Temp Gauge
will post a picture of how i mounted mine , please check with banks before you buy i was going with banks but no trans temp on it......
Well that sucks.. I already ordered it. I mainly want to track boost, trans. temp, and intake temp. . I tried an AFE monitor in my 22' ST and it wouldn't show a trans temp either. The AFE monitor screen was the WORST. It froze up all the time or needed to be refreshed all the time. I even sent it back and ordered a replacement and the replacement worked the same way. They were both complete garbage. I will plug in and play with the iDash for a little while before I put holes in my A-pillar trim panel and mount it. If it sucks, I will send it back.
RAYJAY
Union Dale Pa
2021 explorer limited
here is mine going to wrap or paint the fake carbon fiber is not for me .... 20240818_172950.jpg
here is mine going to wrap or paint the fake carbon fiber is not for me .... View attachment 24610
Not picking...just observing
That's a big circle for such a small display
They could have fitted that on the rear view mirror..companies must think we have a complex about gauges..
They are missing the idea
That's what burns me. The info is available to put in the digital IP. Freaking hell .at least in tow or sport mode..
We want information but dam not looking like wart
Yes I would wrap or paint
The Banks iDash is installed in the 25' ST. It looks good and I really like the mount I chose. Sadly. I havent found trans. temp. in the gauge display options at least yet..
St. Louis
Trans temp is available without the idash.
I haven't driven it yet to see if it exists beyond tow mode like my previous 22' ST had.. Is it in other drive modes on the 25'?
sort of, its like the eng temp gauge they present, its just a swing with no numbers
sport and tow haul should be by default a trans, eng and boost in numerical form,
imo. maybe my f series trucks have spoiled me a bit
#29
Only on tow haul mode and it’s just a gauge. Not an actual temperature.
St. Louis
The option is in your configurable 'My view' from your right hand steering wheel menu.
Oh wow! That's awesome, thank you. I am going to check this out.
St. Louis
I do agree that minimally we should have the same gauge options as the F150.
Is it possible they could release more gauge options with updates down the road? Is that a thing...maybe?
Sadly I doubt it
Funny thing is the info is there already
But IPC is not configured or programed
I did find this as you relayed. I'll deffinately take the trans. temp bar graph over not having anything at all displaying trans temp. Thanks again for showing me this.
St. Louis
No problem at all. Happy to help.
I agree, the bar is not very elegant, but it is something.
Farmers Branch, TX
The Car Scanner ELM OBD2 has transmission temp. I haven't messed with the app much so I haven't figured out how to scale the gauges so 100 degrees is not the max.
Suprawill1
Suprawill1
Thread Starter #37
Ended up getting this. Does everything including all data display coming from the ECU and transmission computer. Of course, DTC, explanation of codes, remedies etc. It auto detects VIN so it is model specific for exact features and sensors. A good deal + for 103 out the door.
I now have real time trans fluid temp display.
https://www.amazon.com/dp/B0D7VZLY3W?ref=ppx_yo2ov_dt_b_fed_asin_title
Farmers Branch, TX
The app I use updated and AA support was added. It doesn't show the gauges, just the text.
Farmers Branch, TX
What app is this and how is it applied?
Car Scanner ELM OBD2, though I'm not sure if there are any features behind a paywall. On Google Play it says "No ads or in-app purchases with your Play Pass subscription", I have Play Pass for free with my Verizon Wireless account, and on my phone the app is Car Scanner Pro when I open it. Otherwise, you just need a BT OBDII adapter and have your phone connected to both that and Android Auto. I just noticed today it was added as an available app.
