Offroad Mods
Hannible
Los Angeles
Hello everyone, im new to this forum and been looking into making my ST a bit more offroadie. I've had the ST for 4 years now and have had fun on the street and now looking into hitting some of the back roads. I know I won't be running with the broncos or the jeeps but just to be able to hit some tamed trails. Looks like we are a bit limited to what we can do to it as far as suspension and lifts. For the lift kit i will be going with the traxda 1.5" lift. I saw there was also a H&R spring lift. H&R 51633 Explorer Lift Springs (20-24) (steeda.com). Wondering if anyone has done both to the ST. I have also read issue with vibration when going on 2" lift. Im thinking i might run into the same issue if i go with both mods without re-engineering the whole trans and suspension but if anyone can verify.
Thanks View attachment 23024
Very few have gone down the off road path you want to go. There is a guy on Facebook who did a pretty neat job turning his ST into more rugged. As far as off road parts, the lift and a timberline skid plate is all your going to find.
Welcome to the forum.
Hannible
Hannible
Los Angeles
I was disappointed that after 4 years there wasn't many mods on the off-roading side, but i did get the street trim which is kind of ironic now lol. Do you happen to know the guys facebook info. Maybe he can guide me and take it as far as my wallet allows it. Thanks again.
Guess I should’ve said there has been only one guy that I have seen of who went more off road. All he did was a Traxda lift, timberline skid plate, roof rack, and beefier tires. I don’t remember his info.
If you can find one from a wrecked timberline snag the entire rear differential assembly, they came with with a torsen rear diff and have the same gear ratio as the ST's. Ask any offroader, having a posi or locking rear is basically mandatory for any real off roading. The torsen in the timberline is the only one out there that fits the ST
It is extremely difficult to find one so if he finds one he needs to triple verify all the numbers show it’s a Torsten.
if OP has the coin, he can buy a new one direct from Ford, but I suspect it will be north of 2K for a complete unit.
Hannible
Hannible
Los Angeles
Looks like I will just be going with the traxda lift and the skid plate which will still help a bit when going offroad but I will definitely go to ford and ask about the torsten differential and the cost for install and everything. Will update when i get answers. Thanks everyone.
2nd if price is not to much of factor
You can buy the springs and the piece parts from ford.
Skid plate is under 150 for transmission
It's the least pricey
You can pull a Vin and shop the different parts at ford parts. To get the skinny
It was me
Change to more off road tire
Do the timberline skid plates and bash plate
Then play bronco sport and have fun
