Tune caused P0035 and P2418 codes
NKestly
Wisconsin
Hi All,
New to the forum but I have done my research and do not see a threat on this. I installed the Cobb accessport on my 2021 ST. It drives great but it keeps popping 2 codes. The first is P0035 (turbocharger/supercharger bypass valve A control circuit high) and second is P2418 (EVAP system switching valve circuit/open). I trust Cobb and have used their tunes on vehicles in the past. But could this possibly be because the later model year 2021’s don’t have the bypass valve and their tune changes something in the ECU to cause these codes?
Welcome to the forum.
N
NKestly
Wisconsin
Thanks! And thank you for your service(s)! @Blue Beast
BBGun242
Iowa
2022 Ford Explorer
Hi All,
I doubt there is anything in the tune that would affect those. I have a 2022 and got tuned by GooseTuned. No Codes.
Late model Ford's are renown for their EVAP Valve Issues.
N
NKestly
Wisconsin
Hard to believe it’s that big of a coincidence that it happened as soon as I loaded the tune.
N
NKestly
Wisconsin
Update on this. I uninstalled the accessport for all of last week and drove about 700 miles with no codes. I reinstalled the tune yesterday and the codes immediately came back. So the tune is what is causing the codes. Any thoughts on this?
BMW X5, Black 2020 ST
Go with @GooseTuned he will get you sorted out.
N
NKestly
Wisconsin
Leaning that way
BBGun242
Iowa
2022 Ford Explorer
Have you reached out to COBB? Are you running the latest firmware on the AP?
Which tune where you running? I ran a full tank on the 87 tune last week, without issue.
N
NKestly
Wisconsin
I talked to them multiple times. They told me to uninstall the AP and drive for a few days. I will be calling them tomorrow again now that I did what they asked and have the same issue. I am running the 93 tune. I also tested it on the 91 tune with the same issue.
N
NKestly
Wisconsin
Also yes, I ran all the firmware updates.
Arizona
2022 explorer ST
Been goosetuned for 3k miles without a single issue , ots tunes have always been crap, let goose pro tune it.
New Mexico
Thank you!
had goose set me up with his tune perfect not problems @GooseTuned for the win
N
NKestly
Wisconsin
He won’t tune for me until I get the check engine lights checked out because he believe there has to be a mechanical issue. I tried that and no issues were found by ford. The codes don’t exist when the tune is uninstalled. Not sure what I’m supposed to do. The car runs great with the tune installed but the check engine light turns on the second I load the tune.
United States
Explorer ST
Does your PCV line have a sensor in the middle of it or not?
N
NKestly
Wisconsin
Thread Starter #17
Is that the short black hose on the passenger side from the intake manifold with blue clips? If so, no sensor.
United States
Explorer ST
Nah, it's this line in the driver's side
https://parts.autonationfordwhitebe...leHBsb3JlciZ5PTIwMjAmdD1zdCZlPTMtMGwtdjYtZ2Fz
Not sure when Ford stopped placing that sensor in line on the hose, but it appears as though having it or not can make a difference when tuning. I think I read on a FB group of someone having this same issue when tuning with ZFG as the original tune accounted for the sensor when the person didn't have it. Might be the other way around, but regardless, the tune needed to be updated to correct for it and the person no longer had any CELs.
N
NKestly
Wisconsin
Thread Starter #19
Thanks for the info. I’ll try and find that in my engine bay. I know ford made a few changes to the ST’s throughout the first few years. That was the first thing I thought about with the check engine light because mine doesn’t have the factory bypass valve.
It's probably the Cobb tune. There are differences in stock tunes depending on your vehicle. Most tuners will take your stock calibration and apply their changes. Even my Livernois canned tunes are given to me based on what my stock calibration is. Does Cobb do the same?
