texas
I installed my CVF intercooler.
St. Louis
Some paint correction, clay bar and compounded the ST today... tomorrow will be light swirl removal and sealer...
May i please ask how did the Wolfgang perform? I've used Adam's, wasn't thrilled with outcome.
Midwest
I have been using only Wolfgang products for about 10 years… tried some others and never got the affect I wanted. I start with Uber Compound, then go to the Total Swirl Remover, then Paintwork Polish Enhancer, and finally the Deep Gloss Paint Sealant.
St. Louis
Very nice. Thank you for the reply. I am going to give them a shot.
Midwest
You bet! The compound and swirl remover should be applied by buffer… the polish enhancer can be applied by hand. It should be applied in a straight line, not in a circular pattern. Sealer can be applied by hand in any manner. Good luck, hope you get the results you are looking for!
Autoworker
New Goodyear MaxLife 255/55-20 tires and all wheel alignment. 48;000 miles on the factory Michelins. $1070.00 out the door.
CONNECTICUT
2020 EXPLORER ST
Ordered CR P Stage 5 turbos - Nostrum Stage 3 injectors - as well as xdi evo fuel pump - next stop drive line and tranny - see ya @ the finish line...
CONNECTICUT
2020 EXPLORER ST
ordered the V2 FENFAB air intake.. LOVE the single filter - it SOUNDS NASTY.. The 2 filter and more airflow is gonna help these stage 5's BREATH!!!
Desert South West
AWE 3" Exhaust just arrived, box was beat up, but the lollipop and all other parts were intact. I was worried about the tips, but they were packed in a separate foam inserted box.(y)
Suprawill1
Daggone, ya tryna make the chassis leave the body behind? What kind of power are you aiming for?
CONNECTICUT
2020 EXPLORER ST
I’d like to go north of 650 the tires… it’s gonna be close - trying to get in the high 10”s - I’ve seen other guys with stage 1 injectors on the pure turbo 650 make mid 600.. with similar set up - I’m just running the CRP and stage 3…
Suprawill1
So, you're using ethanol then.
Suprawill1
Added color matched explorer lettering
Looks nice! I didn't realize silver was an option with that lettering. I might have done the same.
Instead, I went red, to match the ST.
V3nom3nom
Nurse
Replaced original FOMOCO battery with Interstate H6 from Costco. 2020 with 40xxxx miles.
