Recommended 18” all black Wheel
New York
2022 Ford Explorer, ST
Folks, I’ve been searching high and low for a winter set up. I want to run BFG all terrain K03 tires on an 18 inch rim with a much closer to 0 offset. There is absolutely nothing I’m finding that is hubcentric to a 2022 ST. Really hate to use hubcentric rings. Do you folks who’ve gone aftermarket rims find it typical using hubcentric rings? Not interested in the PI rims. If anyone is using a good looking 18” all black glossy wheel, please shoot a link my way.
DaveG ST
Hurlock, MD, USA
How about the wheels off of an Explorer Timberline?
Greywolf
New York
Was looking at those. But I’m trying to go closer to zero offset and not have to add any spacers.
StarWhite22
New York
I got some 18” Enkei wheels and Cooper Discoverer AT3 4S from Tirerack. Really pleased with this combo and set. I don’t think they are 0 offset but I didn’t need a hub spacer or anything. They matched right up.
Tire size is 265/65R18.wheels are Enkei performance px-10
Greywolf
New York
Wow that is sweet looking. Exact look I want. Was that rim hub centric or did you have to get an adapter ring. Seems like every rim I look at is always larger then the 70.5 mm bore.
StarWhite22
New York
It’s hub centric. I didn’t do anything other than take off the old wheels and tires and mount the new ones. Been on for about 5,000 miles and no issues.
Greywolf
New York
If you don’t mind, can you tell me which exact rims you purchased so I can check on the spacing. Also, curious to see what the whole package cost you
I'd get te 18" Timberline wheels if you could find them.
StarWhite22
New York
Yea I was looking at the timberline wheels but Enkei is a pretty reputable brand and I really like the way this setup turned out.
Enkei model #
536-880-6535BK
18X8 ENKEI PERFORMANCE PX-10 GLS BLACK
https://www.tirerack.com/wheels/Whe...rer+ST+4WD&autoYear=2022&autoModClar=Standard
Tires: 265/65R-18 COOPER DISCOVERER AT3 4S SL
total price was $2210. That include mounted and balanced from tire rack along with black lug nuts and black valve stems, TPMS etc.
Tire rack had great customer service and were easy to work with. I’d do it again if I had too. Ride is same as stock if not a little smoother.
Greywolf
New York
Enkei model #
536-880-6535BK
I’m gonna follow you in your footsteps. Love that set up. Seems like the cooper tires are no longer available as the AT3 4S they are now AT3 LT
Greywolf
New York
Enkei model #
536-880-6535BK
One more question while I’m ordering it states that the TPMS sensors will automatically establish connection after about 20 minutes of driving without me having to do anything else. Did you find this to be true?
Edited: For grammer
StarWhite22
New York
Yea it read the correct psi right away. I checked the psi in them once I got them mounted just to put them all at about 33. I didn’t get any low tire lights or anything. Hopefully your process with tire rack is just as smooth. Definitely opt for the black valve stems and they called me to confirm my order cause of the speed rating on the tires being lower and that’s when I asked about black lug nuts and they swapped them out with silver ones prior to shipping so that everything matched. Definitely worth it.
Greywolf
New York
You sold me. How do the tires feel/sound on the highway
StarWhite22
New York
Very smooth. No more road noise than the stock tires.
Greywolf
New York
Hey, I just want to send you a gratitude of thanks. Just got my rims and wheels put on. I decided to go with the falkan at4s. But loving the rims my 24-year-old son said those rims look hot.
StarWhite22
New York
Hell yea that’s awesome!! How are those tires? I’ve always heard good things about them. Looks sharp
Greywolf
New York
Thread Starter #17
Thanks much yes pretty happy with it. Also got some compliments on the rims already.
Those tires were scaring me when I first bought them concerning road noise. But I took them out on the highway and also in the city streets and I was so impressed that they were no different than the Perelli. The only difference is if you hit a very big pothole, the three ply rubber sidewalls made noise a bit more noticeable. But on a flipside, I think because there are three plies on the sidewalks. It also muffled the smaller bumps on the highway. Can’t be happier.
BMW X5, Black 2020 ST
Wondering the weight of one. I'll have to see.
Greywolf
New York
Thread Starter #19
Join the timberline forum. I know a few folks had them for sale. I was going to pull the trigger, but the shipping was out of the question.
