Spc camber bolts. Any good?
Eh69758
Firefighter
Baltimore
Explorer ST
Has any one used these. Are they worth it on h&r springs.
You don’t need camber bolts. There’s more than enough adjustment for any static coil on the market.
E
Eh69758
Firefighter
Baltimore
Explorer ST
I kinda figured as much. I’m going to try out the piu strut so I figured if it helps I’d throw it in. There is a pretty noticeable popping going on and some on center dullness so I’m also replacing end links with the steeda joints.
The front is gonna sit at -.8° give or take .1
That’s perfectly fine and no bolts are needed.
Charlotte
Mine sits at -1.4 on front driver side and -.7 on front passenger side with Steeda springs. They claim camber is not adjustable on the front. So I had to buy these bolts. I wish mine sat around -.8 on both sides… that’d be perfect, wouldn’t have had to buy the bolts.. All my suspension is in good shape, guess I’m just unlucky.
A good shop would have loosened and centered your front subframe. It’s super easy to do but they’d rather sell you parts.
