creeky rear springs/sway bar
dousman wi
2022 explorer st
I installed the steeda springs and rear sway bar and now I have an embarrassing creek going on from the rear when I roll over the slightest bump. I can't tell if its the sway bar or rear springs. Anyone else have this and or possible solutions?
Thanks in advance
Not enough grease on the swaybar bushings.
Chattanooga, TN, USA
Thanks in advance
It's the bar. As far as "not enough", we have plenty on ours and have dropped the bar multiple times to goop more in there. Stays quiet for about 3 weeks.
SeaRay
2021 Explorer AWD Limited Hybrid
Thanks in advance
Check this video out, this is after ford replaced rear subframe bushings 15,000 miles
https://www.dropbox.com/scl/fi/khj7...ge_9.mov?rlkey=62dk5vj26pfvzqlj9a1tjn4x4&dl=0
That's a different sound than our RSB bushings.
We complained to Steeda and they sent us more bushings, which were exactly like the bushings on there. We even used the silicone lube they recommended. Just Google "Steeda sway bar squeak", it's nothing new. Every Steeda swaybar across every platform makes noise. I cut some plastic out of oil jugs and will give that a shot next, if that doesn't work we'll put the stock bar back on.
My Steeda rear bar doesn’t make a sound. Neither does my AFe front bar.
FORZDA3
Gloucester, VA, USA
My Steeda rear bar is silent as well…
... Every Steeda swaybar across every platform makes noise...
I must be driving a one in a million, it just ain't so.
cmauro9
New Baltimore, MI, USA
I’m getting it too and a really annoying rattle too. I haven’t installed my H & R Springs yet. If I push down on the rear bumper it’s more like a squeak.
cmauro9
