ST Audio Control D-5
Had some time this weekend to install my Audio Control D-5 1300 AMP.
The amp is installed under the passenger seat. Added two M5 nut insert to secure the plate to the car.
Still need to run the power wire and speaker wire to factory radio.
Stone17
I order the Audio Control AC-LGD-20 Load Generating Device.
Where should I install the devices? At the amp input?
Stone17
Did some wiring on the amp.
EDIT. Yelp, I see my wiring is backward. Damn it.
Stone17
Had some help this weekend.
Ran the power wire and ground wire.
I found a unused grommet on the firewall just under the battery. (Will take pictures)
Edit: The amp plate is mounted the wrong way. I forget to get better pictures.
Stone17
AMP is up and running.
Finish the power wire and speaker wire. I ordered the plug and play wiring from LLJ customs. It takes about 30 to 40 days to receive the wiring harness.
Ran the battery wire to a fuse block. Made the mount with ABS plate.
LLJ customs plug and play wire. Wiring ran back to the amp.
Stone17
After getting the car back together. I had no front right sound from the source devices.
I ran a panel screw into the wire harness. Easy fix but has to remove the rear panel.
Stone17
I tuned the amp with my laptop. Sound good. The treble sound way to high in some songs.
Looks good. Decent tuning takes a lot of time and an RTA is required to get beyond “it sounds decent”.
Good luck. I’ve got Audiocontrol dsp amps but I’m using a Navtv to pull preamp signals from the Bose so I am presumable getting a cleaner signal.
Stone17
The Audio Control amp has a built in RTA. Just need to tune the software with my laptop.
True but are you actually using a microphone to test sound. The built in Rta is good for a starting point.
DSP and DSP amps have rta capabilities but you still need a calibrated mic to use them. Hopefully you have a good grasp of time alignment, phase and a pile of other stuff…tuning can be exhausting. I probably have 50-60 hours just in the tune…maybe more after the 6 hour session last weekend. It’s very worth it though…best wishes on getting it whipped into shape.
Stone17
What the price to get the speaker tune?
Most good shops that know what they’re doing with a DSP will be about $500 for the initial tune.
Stone17
How do you set the gain on the amp?
The Sub woofer volume is low. I can get the sub to increase by increasing the EQ .
California
I'm recently getting back into car audio and their is a lot to catch up. Have been doing a lot of research on amps, dsp setups, speakers and sound deadening so its a lot to take in. My question is
1. How do you like the tuning process/software of the audiocontrol?
2.what speaker setup did you go with?
The tuning process seemed straight forward. I did my own thought the amps then used a calibrated mic for in car tuning. Spent probably 10 hours on my own.
Having said that, I found a couple tuners close to me that really don’t like working with Audiocontrol so go figure.
I’m running a JLAudio 13tw5v2, morel in the doors.
Probably because their stuff is known for an extremely high noise floor so nobody wants to have people talk bad about their tuning when it’s an equipment issue.
Play a zero bit track at full volume…if you hear anything at all especially in your tweeters…you have noise floor issues.
California
Morel on all doors? Any sound deadening that got done? I've heard mixed reviews on the audiocontrol experience which is why I ask. It seems like more people tend to lean towards the Helix stuff.
Also are you running it from the stereo directly to the amp?
California
I've heard about this as well which is why I asked. Is Helix the go to for dsp? I just spent some solid time reading through the thread of the build you did as well as the sound deadening one. I don't plan to win awards or anything with what I want to do with the ST, but I simply want clean loud sound over the simple amp and speaker build setups I've done. I'm still undecided on speaker choice though, again nothing crazy but infinity kappa series 600 is what I am looking at for now, if I can find the 900s with the 6x9 that would be great but doubt it. Also have you ever tried the lower end focal stuff? Like the flax version? Their is a local guy to me that has a set for a reasonable price. If so what are your thoughts on them?
You can’t go directly from the “stereo” to the amp. You will need an interface of some sort…could be as simple as an Audio Control LC2i or the best money can buy is the NAV TV Zen A2B.
