Audio system working but no sound.
Walterd
Chile
The master reset I'm referring to is in the touch screen. A reset button is under the setting there. You may have done that but I'm not sure.
Yes, I did it already but doesn’t help
Walterd
Chile
Suddenly audio starts to work again !!! After 4 days without audio the system started to work again and I did not touch anything else !!
Really strange isn’t it ?
This is the 2nd time it happens the same way.
What is wrong with the system ? Is there any upgrade I need to install ?
I haven't seen an update for the audio. Are you on the latest version of SYNC? It is 3.4.22251
Walterd
Chile
Sync version is 3,4, this is the picture I took from the screen.
Walterd
Chile
Thats an old version. You have 21194 and the newest is 22251
Is it a way to update to the newest version ?
How ?
#27
Walterd
Chile
#29
Hi, I did the update to the last version. Thank you very much for supporting me on this process. Hopefully this will finally fix the audio problem.
Keep us posted. Good luck.
Super G
SoCal
#30
Has anyone experienced radio, gps and all display operational but no sound. Dealer says update of system was required. Happened twice. And input?????
I just got back from the dealer because I was experiencing the same issue, and yes, I tried the “soft” reset and master reset. Apparently a module burned out and needs a replacement. Once they get the part (Mon/Tues), I’ll go back prob Fri to get it replaced. I’ll take a pic of the actual part they replaced for reference.
Super G
SoCal
#31
So this module replaced by the Ford dealer fixed my “no sound/audio” issue.
C
Virginia Beach, VA, USA
Thread Starter #32
Good that you’re still under warranty. Wondering what‘s the failure rate for the module and out of pocket cost to replace. Was it a low cost easy remove and replace or something of high level difficulty and cost? If anyone have an idea.
douglas.kirsch11
Active Duty U.S. Army
New York
2020 explorer ST
#33
Hello,
can you please confirm the part number for the module? I have the same issue, and the dealership wants $900 to replace it. I found some on eBay for $400 and I have the ability to replace it myself. Just want to make sure I’m get the correct part with NAV and everything.
thank you
Doug
Super G
SoCal
#34
Hello,
thank you
Doug
I believe the part# is listed in the pic…I think it’s the “LB5T18……”
douglas.kirsch11
New York
2020 explorer ST
#35
Now that I have the module, anyone know where it is located? I have seen behind a panel in the trunk area, but also maybe behind the head until. Any assistance or photos should be a huge help.
thanks again
Doug
Bronx, NY
#36
thanks again
Doug
Hi Doug, I just also bought one off ebay and did the install and it solved my problem. The module is located in the trunk area on the passenger side. You will have to remove the plastic panels along the interior for easier access. Everything comes off fairly easily.
Indiana
Hey 22Forged Green. When you did this module replacement, did you disconnect the battery first or just pull the panels and plug it in? I am experiencing this same issue. Has happened off and on for about 3 months and finally no more volume. Thanks!
El_SonicST
Active Duty U.S. Navy
Menifee, CA
I'm having the same issue. It's been maybe a week now since there's been no audio. I'm looking at replacing the amp, but I'm not sure where it's located.
