Audio system working but no sound.
calvinruff
Virginia Beach, VA, USA
Has anyone experienced radio, gps and all display operational but no sound. Dealer says update of system was required. Happened twice. And input?????
Round Lake, IL USA
It's happened every now and then with my CarPlay. Everything working but no sound comes through the speakers. Quick reset does the trick.
Hold the radio power and skip forward button at the same time for about 5 seconds. When you see the screen boot back up just let go and you should be good to go.
Yep…reboot it like the above posts says. It’ll fix it.
C
calvinruff
Ok.. Thanks. Hopefully this wI’ll not happen again. If so, I will try. This sounds better than spending 4 hours at the dealership…..You would thank that a reset would be in the owners manual. Or did I miss it ????
Round Lake, IL USA
Yeah that would make sense lol. I honestly don’t know if it’s there or not. Saw here or on YouTube a while ago.
Did it work for you?
C
calvinruff
Carried to dealer. Waited four hours for what was called a system update. Working properly after they did their thing.
Davidson County, NC
Yes, it’s in the manual.
Walterd
Chile
Hi, I’m getting crazy with this problem.
I’m from Chile and this is the 2nd time that sindenly the volume is not working !! I did the reset already by still not working. Volume shows 0 level even if you try to make it louder but volume buttons doesn’t work either.
PLEASE HELP !!!
I had this exact same thing happen on my ST. Just before the battery went completely dead and locked me out. Resets did not solve the problem. On mine, the NAV also quit functioning.
Walterd
Chile
please confirme how you solve it, once you got it
new battery
Walterd
Chile
It has only 6000 miles, and battery is working fine. This must not be the reason, I believe
Walterd
Chile
Did you do a soft reset or master reset?
Well, I suppose I did a soft reset (hold the audio power button and the skip fowrard for 5 seconds)
I don’t have any clue how to do a master reset.
The one I also did is a reset system trough the configuration.
I also disconect and reconect the battery but nothing what I did solve the issue.
Volume shows 0 and volume button doesn’t work, neither the volume from the steering wheel.
Does the NAV still function, or does it show a symbol (circle with a slash through it)?
The master reset I'm referring to is in the touch screen. A reset button is under the setting there. You may have done that but I'm not sure.
Walterd
Chile
Nav is working fine. In some small cases the GPS shows like not working (circle with a slash on it) when going trough a tunel under ground.
