Center console and cup holders
TBONICS
East Canton, OH
Noticed the front cup holder was busted on one side after purchasing it last week. Bottom was only held on with little plastic rivets. Ended up using a soldering iron and fusing the pieces together. YouTube helped me remove the console, but provided no help accessing the cup holders. It comes apart front to back.
i8iridium
I wish you were able to get some part numbers out of there. There's a lot of ppl (including myself) that would love to get the ambient cupholders in their new ST.
T
TBONICS
East Canton, OH
Not sure but I think there are some posts on the forum about that. Not sure if they list part numbers. Just remember searching for “cup holders” or something along that line and there was a thread about that.
i8iridium
Nope. No part numbers that I've found. I'm just going to wing it at some point.
T
TBONICS
East Canton, OH
Well shit. Wasn’t sure. I couldn’t remember.
Germany
Ford Explorer 2021
Hello TBonics
I would like to foil the silver console in the middle and remove it for this, in your pictures it only looks clipped, is that right? or do I have to remove the entire middle console to remove the silver part?
T
TBONICS
East Canton, OH
Hello TBonics
You have to pull the entire console out. That's not that bad. Once you pull the console back you have to pull the silver trim from the forward cubby to the rear.
Been so busy I haven't had a chance to make a little video.
Bridgewater, New Jersey
I have the manual that came as a repair manual on a CD. I can check and see if it shows the console and all the part #'s for it . But I have a 2022 st.
South Carolina
Hello TBonics
is this the section you are trying to replace? I am trying to get it off so I can get access to the buttons to clean. They are sticky from the wife not putting lids on her drinks
The pic you have there looks like a cover piece sold to change the appearance of the console. I certainly could be wrong but those look like stick-on pieces. You probably need to go beyond just those pieces to get to the things you want to clean. I'm thinking the console would need to come out.
Bekap353
Stevensville, MT
Explorer Platinum
Any chance you could describe pulling that center console up to do that? I pushed my cupholder in on accident and it’s so annoying! Looks horrible and it’s gobbling up random items I accidentally put in there.
Massachusetts
2023 ST
There are videos on Youtube on the process, which will help give you a good visual. Below is just one as an example.
The cupholders can be repaired. There are 4 plastic spot welds on the bottom of each and what happens is they fail and push through. Folks have reinforced the old ones (or new cupholders) by drilling a small hole next to the plastic spot welds and inserting small bolts and nuts. That would completely fix the problem.
Here's a photo of a cupholder I have on my bench. You can see 2 of the mushroomed plastic welds here. There are 8 total. If you can reassemble the cupholder properly, take a drill and drill into the flat area next to the plastic welds and insert small nuts/bolts and tighten up. Done.
A new cupholder is about $75 or so. If you go new i'd probably reinforce it as well with hardware.
