Catalytic Converters
Charlotte, NC, USA
Catalytic converter #3. First 2 replaced due to crack at the weld, passenger and driver side. This one is driver side. This is NOT at a weld, but a fractured pipe. Closest weld is at the very top where a support hanger rod is welded to the top of the cat pipe. 45 years of driving vehicles with CCs and I've replaced more cats in 8 months than the previous 45 years. Good news all covered under warranty, and available. China balloon mystery solved.....pallet of CCs to FOMOCO express delivery
Is yours a MY2020? When you had them replaced, did you get one the new version with the cast flange?
M
Charlotte, NC, USA
Yes 2020. Not sure of the cast flange. Assuming you mean where it bolts at the engine. I’ll look this weekend. I’m putting muffler tape on it so it doesn’t sound like a 60k POS beater until I can get it in to replace.
LondonST
london, ontario
just had mine replaced yesterday under warranty as well. boy do they stink when breaking them in. bonus that they also did the blue screen back up camera fix as well.
zdubyadubya
jeez. at this point I would just be walking into the dealership with a set of aftermarket catted downpipes and tell the service advisor "here put these on and hang onto the FoMoCo supplied ones for a rainy day".
M
Charlotte, NC, USA
Is yours a MY2020? When you had them replaced, did you get one the new version with the cast flange?[/QUOte
Appears I did. While I can't get a clear view from under the car or up top, I checked the invoice and it listed M1MZ-5E212-A and M1MZ-5S213-R. Both listed as Converter assembly. Said it replaces L1MZ series . Best I can tell the new series has the cast in flange. Pictures I can find show a much more robust design.
Honolulu, HI, USA
Mine also, 2020 ST. Part of recall about exhaust smoke in the cabin on hard accceleeration. Done twice over six months and finally okay.
Skeek
Oregon
New here and curious what prompted you to identify this issue. Was it a loud noise or smoke from the exhaust? Just picked up a 2020 ST and am wondering if there are any symptoms I should keep an eye out for.
it may be louder, you may smell exhaust in the cabin but you may not. Best way is visual inspection. It's hard to see the welds by the flange. my crack was the weld further down. also the flex sections in the midpipe are prone to rattle then fail. keep an eye on those too.
Honolulu, HI, USA
My 2020 ST had exhaust cataylitic sulphur smell at start. Got worse over time. Under hard acceleration, cabin would fill with exhaust smoke in short time. First repair failed. Second time has worked now for about a year.
Skeek
Oregon
Nothing on cold start for me but I do smell it a bit on HARD acceleration, which I didn't find too unusual at first. No visible smoke that I could notice. Thinking it might pay to have it checked under warranty though if this is a known issue,
You should not have exhaust smells in the cabin, period! If you do, tell your dealer and have them check, preferably when you bring it in for an oil change or other. They shouldn't charge you if you are under warranty.
M
Charlotte, NC, USA
sounds like a hole in a muffler. Very noticeable when idling. Look for black staining on the pipe. 2020s have a recall on them. Next time on a rack have someone check it out. Cheers
Honolulu, HI, USA
Mine started the same way, small at first, then got worse. Get it fixed.
South Carolina
Are these signs of failing catalic converters? I plan to get aftermarket exhaust and Downpipes in the future. I have not seen smoke or smelled exhaust fumes. However, only one time I smelled rotten eggs a week or 2 ago.
Honolulu, HI, USA
Mine was from bad weld that was quickly fixed at the dealer under a recall notice. I had it done while the car was up for an oil change. It took a second visit to get it done correctly about a year and half ago.
that black soot isn't necessarily a problem. BUT when it's coming from a weld, there is definitely a crack there. Bring it in...
Jessup, MD, USA
Mine cracked yesterday while installing a Thermal 3" exhaust. I know it's covered under warranty, but do you think they would turn me away due to the catback?
I have a set of Whoosh DPs, do you think it would be hard to find a dealer that would be willing to throw those on instead?
