Focal, Mosconi, Illusion and Helix build
Thread Starter #261
A-pillars are done. Wrapped in suede, “deflex” pad behind midrange and CLD on back side.
F4552047-9E65-4F62-8AEA-33DE03155675.jpeg B1350BB5-1ECD-4DD9-AEB3-AE54EED624EE.jpeg A49C3FDC-54D7-496A-A67A-B9D1AEFE7582.jpeg
Thread Starter #263
My left foot will be back by the seat like it’s always been.
@UNBROKEN, you no doubt have the knees you were born with.
Nope…but I do have lower back issues and pulling my leg back takes the pressure off that.
Wow, can't believe an aftermarket knee will allow you to sit like that.
Thread Starter #267
I meant I was born with good knees…and now they’re not. Too many years of running 7-8 miles a day.
Gotcha, I was inferring as it is for me with aftermarket parts, no way they could be bent for more than about 30 minutes. I am however glad this setup works for you.
Thread Starter #269
Front is back together…now to tackle the back part. BA0978C9-FC2B-4E79-BD9F-4C1171F9C8FB.jpeg
Thread Starter #270
New Helix Ultra DSP, RSD Custom Cables RCA’s and new power distribution all installed…and I barely got it all crammed in there. It’s all re-wired and test fired and ready for tuning. My grilles for the kick panels will be cut from 3/16” stainless tomorrow then I can fab the rest and get them protected. It’s so close to done I can’t stand it. FCF8CCC9-13C6-4C5B-8680-C026E2162442.jpeg DD0E5062-BFCE-4DE8-9F32-AB4FC93C8ACB.jpeg BAE43F52-43DF-4453-9DEB-7FEA335ACCE5.jpeg
Thread Starter #271
Grille inserts for the kick panels. 1/4” stainless steel and strong AF. D0E1CDFE-250E-4095-8315-9E3C9BA5AF7E.jpeg F8FD7008-744A-4E9E-A833-F2BC5FA1ACF0.jpeg
LA, California
At the point, ST stands for Song Tuned on your vehicle.
Its like a Jukebox with an engine and four wheels.(y)
Thread Starter #275
So I did finish up those grilles. The plan was to inset them into wooden rings and cover the whole thing with grille cloth…but that turned into only wrapping the rings so I can still see the speaker cone and adding some cap screws to match the sub mounting in the back. F312602B-2C89-4DD3-A7F5-75EF5B204695.jpeg
Like things sometimes do…that got my brain spinning and it’s now evolved into this idea which went to the water jet place today. The new grilles will match the style of the Focal tweeter grilles and will be inset into a polished black acrylic ring. That will match the trim ring going on the midrange and also tie into the piano black dash trim. Then I had to match the screws to the bevel head titanium screws in the tweeters so $5.40 per screw later those will be delivered tomorrow. Basically my grille idea restarted from scratch.
23CD711F-BBCE-4648-930C-9FA8BB8874DC.jpeg E0E68A01-D4A7-4830-84BE-14349D9C7FDD.jpeg
Thread Starter #276
Some “next step” stuff. I’ve always wanted to try differential rear fill. You basically apply 50% of each side TO each side in the DSP and it extracts the center information and leaves the edge info. When done right it can make your front stage both wider and deeper than it already is. It’s one reason I moved to a 12 channel DSP. Just something I can’t resist playing with.
Since it barely plays volume wise as it’s supposed to mimic a reflection and it’s a narrow range of about 400hz to 4khz a wideband driver is perfect. I’m gonna use a Mosconi Atomo 2 amp which is a palm of your hand sized class D amp and Blam FRS 3N50+ widebands in custom pods where the oem speakers are in the d-pillars. D380E97B-C6D9-4F27-A3AD-B6D1F90816BC.jpeg 0AE37C2E-25D7-4C5D-9935-26E5A0203701.jpeg
Round Lake, IL USA
So much fun watching this.
Thread Starter #279
Thought this was interesting. My new midbass grilles are cutting as I type. 8” OD, 1/8” thick 316L stainless steel. 618” of total cut with 332 pierces between the 2. Roughly 3 hours to cut on the water jet.
