Wider tires?
BigAnt75
Haslet, TX, USA
Just got lowering springs installed and I want to keep stock wheels. What size tire can I get to make it flush in the rear? Or do I need new wheels as well? I do not want to run spacers either….anyone have a set up they are using currently as I will be in the market for new tires soon.
You can set rear camber to -.5° the make the top of the tire pretty much the same as the front. That will leave both ends inset roughly an inch. You can’t put a tire wide enough to make it flush on the stock wheel…you’re talking like a 325 width….obviously that’s not happening. You can easily go up to a 295 on the stock wheel…that’ll help and extra width always looks better overall.
Easily? I thought you can't go over 285 on a 9 IN. rim and even that was pushing it.
Waupun, WI, USA
Does anyone have pics of 295/40R21's on stock wheels(with or without spacers)?
travish325
KY
I need to see this.... Cause I'm considering trying 295s on the stock 21s but I'm nervous it ain't gonna work
Tons of people in the FB groups have done it. It’s fine.
travish325
KY
US
Hey @UNBROKEN - sorry for the ping... relevant to thread...
I've got a set of BC Forged wheels, 22x10.5. I'm seeing two options for tires right now at 305/35-R22: the MPSS and obviously the Lionharts. I'm considering going with a 295/40/22 which would allow me to run Michelin - Pilot Sport All Season 4. This saves me a bit of $, they have a longer warranty, but I am a little sad to not run 305s. The MPSS aren't all-season and are crazy expensive. The LH scare me - I really don't want my kids riding on discount tires from China.
What are your thoughts on this configuration or alternatives?
Myself and literally everyone else running them haven’t had a single issue with the Lionhart or Lexani tires. Mine saw 141 mph today on the way home and have been thrashed on triple digit runs more times than I can count and road trips from Houston to NE OK and Big Bend and I’m prepping for a run to CA now. The only thing I did was buy an extra tire to throw in the back on long trips since the 305/35 is such an oddball size and you never know what you’re gonna run into on a trip.
Are they on the same level as an MPSS? Hell no…but they’re very solid tires for the money.
A 295/40/22 will fit fine too though…no worries there and lots more choices too.
travish325
KY
Yeah waiting for this as well cause I have a set in my cart ready to order lol just don't wanna be the ginny pig for it.
travish325
KY
Can you rotate the lionharts from side to side? Or are they specific "outside and inside" marked?
There’s an inside and outside, yes. They’re not directional though and can be rotated side to side.
travish325
KY
Dang that doesn't help me... My issue now is wearing on the insides from the camber on these HRs. No one has been able to get the rear aligned in spec and I've burned through this set of tires pretty quick. I need to be able to rotate the inside to the outside.
It’s shocking to me that people still can’t align these things. Tell your idiot alignment shop that we figured out 3 years ago the rear camber adjustment is the upper control arm where it meets the frame. Yes they’ll have to reach way up there. No it doesn’t look right. Yes that’s where it adjusts from and it will easily get into spec.
^^^^This! Even two Ford dealers told me they couldn’t get it in spec and sent me home with the rear way out of spec. Looks and runs better once I found an alignment guy without his head up his a$$.
travish325
KY
I will give this a shot when I put new tires on...
Btw do you have any links or screenshots from the FB forum with people running 295/40 on stock 21x9 wheels? I don't have FB so when I search I don't get anywhere.
I don’t save stuff like that so no, I don’t.
travish325
KY
Well I order a set of 295/40r21 Lionharts just now. I will update everyone here with the fit on the stock 21s.
travish325
KY
Went to my local dealer after 4 alignment attempts and showed them a screenshot of this..... they got it perfectly in spec afterwards lol
