Late 2022 with four bolt subframe?
Kansas
2022 Rapid Red ST
I am seeing postings on ST Facebook that late 2022 have four bolt subframe??
That would be welcome news. I wouldn't mind replacing my MY2020 with a new one at 100k miles but not if it had one bolt. I'm at 60k miles now.
st8
Bel Air, MD, USA
Yeah I saw that as well. Definitely further admission of fault or wrongdoing by ford. No matter the cause. Assuming this wasn’t a fluke and is the normal moving forward.
Sgt1411
BC&AZ
I compared that photo to mine, I still see same two bolts on rear subframe. Are they saying Ford went from 2 bolts to 4 bolts?.....where are bolts 3 and 4?
Yah wondering that also.
There are either 3 or 4 (although some just like to count how many are visible in the rear, 1 or 2). The other two are on the front of the rear differential and bolted in the down-up direction.
RobHalo
NJ
For this issue, people are looking at the largest high-center bolts to the right and left of that QR code sticker. A 3 bolt subframe only has one of those bolts installed, 4 bolt has both.
Kansas
2022 Rapid Red ST
Here is a picture of my three bolt.
FORZDA3
Gloucester, VA, USA
Uh oh. If the fire starter guy sees this thread he’s likely to blow a gasket! Ford actually fixing the root cause of their self-induced problem he says doesn’t exist! Oh, the humanity(!). No, not humility.
Bowie, MD, USA
I don’t think he ever claimed (although I am wrong the majority of the time) that there is an issue, I think he was attempting to show that the issue was negligible to the amount of reported occurrences. I will not re-read the 7k posts to prove myself wrong I am sure he made the comment at some point.
Peoria, AZ
My '22, ordered in March 22 delivered in Oct 22, has the 3 bolt :(. I got the AWR rear diff mount to help out. I know that these brackets don't necessarily prevent the 3rd bolt from snapping, but it does make it where when it does snap, you can limp it along with the diff mount holding up the diff. It has a bracket that bolts onto three of the bottom bolts of the diff cover, and a wide poly bushing that connects to a mount that bolts up to the subframe. Solid as a rock and the bushing allows for flex and play from the torsion of the drivetrain.
I’m very ignorant to mechanical issues, can another bolt simply not be put in? Does it need a whole new subframe? Is it possible to just bolt the fourth bolt on there?
Whole subframe needs to be replaced.
This. There is a hole but no bushing installed where the second bolt would go. Suppose somebody could fab a bushing sleeve in there but that’s beyond my fab skills, hence my replacement of the whole shebang.
CareerFiremanGuy
The overwhleming majority of ST owners will never spend the time and $$ to replace whole subframes, and Ford knows it.
Ford also knows 3 bolt ST's are still going to roll off dealer lots with people lining up to buy one regardless of how much others whine about it.
Owners should get a brace if they want to safely make more hp, or go and spend an $85k for a 12 mpg Durangpo SRT and shush already.
I wonder if the fact deniers here will ever connect with reality.
