Every time I fill up my tank with gas my ST goes into “panic” mode!  First off when I put the fuel nozzle in (no matter what level is already in the tank) there is a “puff” of vapors that is released. I then fill my tank and the car usually stalls (or if it is not running) doesn’t restart. I have to pump the pedal several times and prime the crap out of the engine to stay running. It runs fine once I get it primed and humming. Randomly it throws the EVAP code (which I clear with my OBD). Overall it runs ok but I do not want to go to dealer if this can be a simple fix. I purchased the EVAP purge valve (no diagrams online to show where it is) figuring that would rid the code and maybe the problem. Any ideas where it’s located (some say next to throttle body, some links say underneath…)??  Don’t think it’s fuel filter.  Any and all help welcome. Thank you in advance.
JB
								JB
