Headlight Water Condensation
BigAnt75
Haslet, TX, USA
Was washing my the ST this afternoon and I saw soap in the headlight housing..has this happened to anyone else before as this is the first time I’m seeing it on my car. Is this something I need to worry about and take into the dealer??
I would be taking it in. Hope you can get it covered under warranty.
I noticed this recently too but it seems to drain out in a hurry. My headlights have not had a problem with condensation lingering so Im guessing this is normal?
I doubt it's normal. That soap bubble won't drain out. It will dry there and leave a film. In time it will only cloud the lens. I would go straight to service and show it to them ASAP.
Yeah, they should stand behind this. It isn't a little condensation the goes away, it will cloud the lens over time.
ARC
Oak Lawn, IL, USA
2022 ST Black
I have the driver side fog light with lots of condensation and it is a bit loose.
Going in Thursday for them to look at it, we will see what hey say.
I'm glad I didnt put the intercooler in yet because you know those bastards at the dealer would try to make an issue of it rather than faulting Ford for the bad fit.
Louisiana
These have been known to have condensation in them. Took mine in to dealer they told me it was not a problem the headlights have holes to vent. Hope this helps you out.
Found some shoddy sealant in the inside top of the driver's headlight. Used some sealant to close it up. 3561F3D3-B62C-4721-BE05-8839F24B4DF8.jpeg
Louisiana
Pomp
Found answer in my owner's manual on page 86 under lights.
