Global Windows
Surrey, BC, Canada
Does the ST have the global windows option? If so, how does it work or active.
Thank you in advance
KegsBdry
WashDC
This works on the ST.
On the key FOB, hit the LOCK then HOLD down the UNLOCK button for a few seconds. It'll roll down the DRIVER'S SIDE/PASSENGER'S SIDE WINDOWS (maybe the sunroof too - cannot remember).
S
Surrey, BC, Canada
Thank you for the info! That part works fine, what about the the lock/window close part..
Toronto, ON, Canada
No Sunroof.. And doesn't close.. Only open (down)
KegsBdry
WashDC
Yeah, it SHOULD close as well as open. It’s a process to get the windows back up from a locked, off vehicle.
But they serve a purpose. I open them when I’m walking up to the car to get the heat out.
S
Surrey, BC, Canada
Only opens, doesn't close
Madtel4
Madison, Kansas, KS, USA
I had my driver's side window stop 1/2 way up on a 97 degree day, 20 miles from home. The local Ford dealer service department had gone home. The passenger side worked but not from my driver switch. The switch on the driver's side would work the back windows. I shut the car off and opened the door several times. No help. After I got home I went out after 20 min or so. Then It worked as it should???
Lee
Dough
Sheboygan, WI, USA
I have tried all comboinationsb but no luck. In the screen I do not have Windows as a option.
Will using an OBii help change the configuration?
Doug
Kansas
2022 Rapid Red ST
That feature does require the moon roof option.
