Anyone use Apple Watch for remote start?
SOUTHFLST
South Florida
Noticed that the FordPass app shows up on my watch. Decided to try the remote start function. Yup, it works.
I used my phone a few times but it's pretty slow. Just use the key FOB now.
st8
Bel Air, MD, USA
Yeah works pretty good for me.
South Palm Beach, FL, USA
Yes, it worked great! I used it for the Spartan race when I did not want to take anything but the watch. It is also a good redundancy to memorize the door code just in case.
Tommy
Philadelphia
I use shortcuts that query Ford Pass API so that I can just press the button (rather than holding) or tell Siri to start it.
SOUTHFLST
SOUTHFLST
South Florida
Interesting. I’ll have to try that. Any tips?
st8
Bel Air, MD, USA
Yeah please share. FordPass doesn’t show up in shortcuts for me.
SOUTHFLST
SOUTHFLST
South Florida
Same. Thought I was missing something
SOUTHFLST
SOUTHFLST
South Florida
Edit: found it.
Setting > Shortcuts > inable private sharing
Then the FordPass app showed up.
st8
Bel Air, MD, USA
Edit: found it.
Hmm I did that and still don’t see FordPass. I did find that link you posted as well. I did all of it and not working.
SOUTHFLST
SOUTHFLST
South Florida
This comment below may help.
“Run a shortcut, any shortcut, then go back to the setting and it will be available.”
st8
Bel Air, MD, USA
Still not seeing it.
But I did see a comment in that post that said this can’t be used if you use FordPass app to already control your car. Which I do.
JohnE
Vancouver, WA, USA
My app shows up on my watch and I didn’t have to enable private sharing.
Philadelphia
Original thread on reddit
Looks like the OP updated the token script as I did recently. Apple seems to have broken Shortcuts (for everyone) in the watch. Reported to be because of Apple Watch update from December. Not sure when a fix is to be expected. Amateur guess, privacy settings are mismatched from the iPhone and we can’t change them for the watch. Clearly these two teams aren’t talking at Apple.
Note: You have to edit variables in the ‘Fordpass Settings’ shortcut with login info.
Philadelphia
Not true, I used shortcuts and the app at the same time. With shortcuts having issues lately, I’ve had to switch back to Ford Pass. I don’t like app, but when it works, it works.
st8
Bel Air, MD, USA
It said it right in the post from the link that was posted from the creator. Maybe it’s just outdated and not true anymore though
so you had all those ford shortcuts working through shortcuts and it worked with Siri?
KegsBdry
WashDC
In the winter, when I get my credit card and check back at a restaurant, I remote start the ST from my phone. That way it's so warmed up for the family and I when we get there.
