Forscan not allowing to write ipc module
Kansas City, MO, USA
I have a 2021 st and I'm trying to disable the seatbelt chimes. I've already went through every other module and reconfigured everything I wanted, but forscan isn't allowing me to write in this module only. Anyone have any input or experience with this issue?
what adapter are you using?
CA
What is the exact error you're receiving?
Why do you need ForScan to disable the seatbelt minders?
As gearhead 1 said, why? You can disable the seatbelt chime without forscan. It's in the manual how to turn them off.
