Yellow fogs
zdubyadubya
I agree!!!
I tried it on mine...it wasn’t working with the silver.
Kirk ST
Pittsburgh, PA, USA
Did this quick mod and really like the look.........
those look good. I also like how you painted all that trim below the grill/lights. Did you do the whole vehicle or just the front? Also, what are the black marks on your hood? function for heat/air or just decorative?
B
El Paso, TX, USA
all painted........
Mustang hood vents.......
Lake Wylie, SC, USA
Is that the yellow Lumin-X pre-cut tint? If so, did you do it while the fogs were still on the ST or did you remove them to install? I ordered them along with the rear reflector tint and the reverse light tint, and they just came today.
B
El Paso, TX, USA
It is the Lamin-X but I went with a universal sheet....I think 9"x16" . I cut the sheet in half to make 4.5"x16" and did the install while on the vehicle . Super easy job ! I don't like the pre-cut because it doesn't really allow for much error . I also used a small hair dryer for install . Took me about an hour for both lights and that's just because I was being super careful with the trimming so I could tuck some of the excess between the light and body panel .
Lake Wylie, SC, USA
Thank you so much for the quick reply. I'll report back on how the pre-cut install goes. Also, the hair dryer tip is gold. Thank you!
B
El Paso, TX, USA
Light use of the hair dryer just to make it a little more pliable .
B
El Paso, TX, USA
Can you please tell me where to get the black and red ford oval?
I found it on Ebay but I haven't seen them since . You have to make sure they will fit your Explorer because there are plenty for an F150 .
Houston, Texas
Thank you!
Houston, Texas
looks like there's a couple doing them on ebay
ebay listing number : 293413037773
ebay listing number : 313269703221
I appreciate the help, thank you.
Houston, Texas
For the life of me I cannot understand how the lamin x fogs work. Been sitting here for an hour trying to figure out how they are supposed to work.
Rick4345
Illinois
2024 Ford Explorer St-Line
Did you ever get it figured out? I'm in the same boat you are, or were. My second set is supposed to be here today.
