Tail light removal
Gig Harbor, WA, USA
Quick question...trying to remove the interior plastic cover. What’s the best way? I am having trouble getting it out. Use a knife to grab the side?
Granite City, IL, USA
I just used a small flathead screwdriver from the bottom of the panel. Took some pressure but it will come off.
mkuluz
Gig Harbor, WA, USA
Thanks. Yeah I wasn’t sure what side to pry off first.
If you’re gonna do much interior disassembly some trim removal tools are cheap insurance against scarred up panels.
mkuluz
Gig Harbor, WA, USA
Ill do am Amazon search. Thanks
Murrieta, CA, USA
I stripped one of the torx screws last night . Now I gotta use a dremel cutting wheel to cut a slot in it. Hopefully comes out with a flat head. Might end up replacing the trim piece too as I’m sure I’m gonna nick it. Pissed.
BrianL603
New Hampshire
2021 FORD EXPLORER ST
Can I get some help? First off I broke the cover off the access for the left side tail light. I also lost the piece that went on the outside of the of the tail light that gets screwed in. Don't ask. I added a pic of the right side as an example.
Minneapolis, MN, USA
Man, I was planning on throwing in some LED bulbs for the turn signals (rear) and reverse but all I see is people breaking the cover....
Jeppo
Davidson County, NC
Perhaps I’ve been lucky but it is possible to do this.
Bowie, MD, USA
No need to remove the BIG Torx bolts from what I remember. Hardest part is the pin that is forward to the front of the truck on the lens assembly. I ended up using a towel and small screwdriver to pry out, with a lot of praying not to scratch the paint. After I watched some YouTube videos to see if there was an easier way and everyone just yanked them out so I am not sure what the best way is but scary when doing.
randyknight
Chelsea, AL
This video is a good guide on how to remove the tail light and trim.
Bowie, MD, USA
Ha. He made the front pin look like it just falls out. No chance.
randyknight
Chelsea, AL
Pulled right out for me on both sides with no issues.
2022 Ford Explorer Platinum
Great tutorial! Thanks for taking the time.
