Oil catch cans
NYC, NY, USA
The 3.0 in the ST is only DI.
The UPR kit is way overkill. It requires A LOT of extra work. Just get a JLT, save a bunch of money and a lot of time and catch between 80-95% of what the UPR catches. JLT takes 20 minutes to install.
Just ordered the jlt
but wtf i swear I thought they were dual gdi, smh ford
LokiWolf
Henrico, VA
Some are both DI, and Port, like the 2nd Gen 3.5.
Sent from my iPad using Tapatalk Pro
Vancouver, WA, USA
Hmmm thinking of pulling the trigger on one,
But doesnt the eco boost have port and GDI? Does the valves still gunk up with PFI?
The 3.0 EB has direct injection only, no port injection. I believe the 3.5 EB does have both though.
NYC, NY, USA
I just checked inside the tube it there was a good amount of oil in it, not just a light mist, i shook the tube and drips of oil came out.
catch can 100% a must!
also i only have 450miles on this st
LokiWolf
Henrico, VA
#26
Correct, Like I already said. The 2nd Gen 3.5 has both.
Albuquerque, NM, USA
#27
money is no big deal. just work more!
LokiWolf
Henrico, VA
You can remove the JLT kit in 20 minutes, and put everything back to stock. ZERO permanent modification. Have always thought the UPR is overkill. Does it collect more, yes. Worth 3 times the price and 4 times the pain and permanent modification...I personally don’t think so. If you do, that is cool.
NappyNick
Active Duty U.S. Navy
AZ
#30
Who has the best deal on jlt catch cans. Ready to buy.
zdubyadubya
I don't know about any deals but the JLT is already fairly inexpensive. In those cases I usually try to support the outfits that in turn come onto the board and support the users and answer questions. @ron@whooshmotorsports posts fairly frequently and stocks them. I'm sure if you gave him a shout he would be happy to take your order.
Murrieta, CA, USA
#32
NappyNick
AZ
#33
There’s only one for the st right. Just the passenger side? For some reason I thought it was both driver as well.
zdubyadubya
UPR is the only outfit that does a clean side separator.
NYC, NY, USA
#35
just checked my JTL can after like about 150 miles, had about a cap full of oil in it.
How much is a "cap"? Is that more than a smidgeon, a pinch, a squirt, or a dollop? ;-)
DoingOK
Smithfield, Virginia, USA
#39
JLT is located about 25 miles from me. Jay's products are always well designed and seem to work well.
