MPG in Sport, ECO and Normal Modes
ezridermn
Does anyone know if driving on the highway in Sport Mode at a constant 70 mph decreases MPG compared to ECO or Normal mode?
OHST
Cincinnati, OH
As far as I can tell only the shift points are different, at a constant speed I see the RPM levels are the same.
Vancouver, WA, USA
I don’t believe that it will shift past 8th gear in Sport mode. Your cruising RPM’s will be higher therefore less MPG. At least that’s what I’ve seen at freeway speeds. Maybe it will shift up at higher speeds.
Seattle, WA, USA
From what I've read Sport mode tweaks include: sharper throttle response, weightier steering, and less restrictive stability control. But on the way to work this morning I shifted to Sports mode at 70mph and you can see the RPM jump with more engine noise. The only problem I'm not sure what gear in goes into since it's not displayed anywhere. I would think MPG would drop in Sport mode.
Vancouver, WA, USA
If you tap the + paddle shifter, it’ll show you what gear your in. When you paddle shift to go to a higher gear in any of the modes, the next gear up will blink if you’re not going fast enough for that next gear. So if 8 blinks, you know you’re in 7th. Or you can just press “M” for Manual mode and it’ll show you what gear you’re in too.
CapTom
Anderson, SC, USA
I just did a 100 mile highway round trip. The first 50 in ECO mode and the return in SPORT. According to the trip gauge I got 26.9 in ECO and 25.5 in SPORT. SPORT was a lot more fun.
Blackssr
From what I understand Sport Mode does not have OverDrive. Only gears one through eight.
Mine will go through all 10 gears in Sport mode...it’s basically the only mode I drive in.
In city driving, I can get one or two more gears available in normal mode but seem to be limited to 6 in Sport. But at highway speeds, all 10.
Symetry
West KY
Is it your tune that gets you 10th gear in Sport mode or will it go there in all modes without the tune?
Jim
Blackssr
Hmmmmmm.. I thought I read that overdrive is disabled in sport mode. Is there a way to see what gear you're in while driving in sport mode?
Did you find a way to make it boot directly into sport mode by the way?
Blackssr
Jim
I'm curious as well. Palm Beach Dyno is supposed to get back to me on exactly this question.
It could be the tune...I don’t remember what if it did anything different before then. I have the gear showing at all times in the tune and no, there’s no way to default to Sport mode. I wish there was.
Symetry
West KY
I don't have a tune yet,
I'll be getting on the interstate next Tuesday , I'll put it in Sport mode, and manual mode and see if it says 10th gear.
Jim
Jim
All you have to do is hit the paddles. It’ll show the gear for a few seconds.
New Windsor, MD, USA
No tunes here and was at 10th gear in sport mode, I'd post the pic my wife took but it's not very good
PostmanRP
Central Fl
I’m stock and tested sport mode today. Over 60mph and cruising it will go into 10th gear. Saw the rpms go under 2k so hit the paddle to see and 10 popped up
Blackssr
I confirmed 10 gear last night @ 70 mph and 1800 rpm while in Sport Mode.
