Anyone considering adding aftermarket subwoofers?
Toronto, Ontario, Canada
Ended up putting an entire aftermarket stereo in. It involved removing the third row as planned. I have 2 jl audio 12 w6’s powered by an arc audio 2000.1
Hertz Millie 6.5 fronts
Morel virtus rears
Jl 400/4 to Millie
Alpine power pack to rears
JL audio fix 86
All hardware hidden
I forgot to ask you but did you upgrade your battery or add an extra battery my installer is a little worried about getting Electrical errors. Thank you
Stock battery for me no problems!
Ok thank you. We did end up ordering a battery for the back because he was worried about rhe extra draw in current because I have 3 amps in the back that have a crazy amount of draw.
My ST is Better!
This is my set-up on a stock battery.
Check out Frostbitebox.com for sub enclosures. They have the "Gravity Series" Sealed/Downfiring in a single or double configuration accomodating 10" and 12" subs. Just got mine for my JL Audio Shallow 10TW3-D4. View attachment 699
Anybody know what happened to Frostbitebox.com ?
Long Island, NY
Unfortunately they went out of business due to the COVID shutdowns. Very sad, Bruce the owner was a stand up guy.
FOXBOX had a fire back in December and they've been temporarily shut down. MTI Acoustics is another option, they're out in Texas.
Thank you! I guess I will wait for FOXBOX, looks like MTI only does pickups.
Long Island, NY
They will ship to you, use the contact form on their webpage to send them a message to get a shipping quote. They are very good in responding back to you.
thodrinsky
Hartford, CT, USA
My set-up:
NAVTV ZEN-A2B...................................................RETAIL $549.99 YOUR PRICE $500.00 ( Factory audio interface )
FOCAL EC165KX3................................................MAP PRICE $2299.99 YOUR PRICE $1889.00 ( Front three ways running full active )
40' JL AUDIO 0 GAUGE CABLE PACKAGE........ YOUR PRICE $400.00 ( Super hi quality 100% OFC copper wire for both power & ground from battery )
CABLES FOR "BIG 3" UPGRADE........................YOUR PRICE $100.00 ( 100% OFC copper wire for Alternator to battery, engine block to chassis & battery ground to chassis )
MOSCONI 6TO8PRO DSP.....................................MAP PRICE $799.99 YOUR PRICE $689.00 ( 6 channel in / 8 channel out full suite DSP )
MOSCONI RCMINI.................................................MAP PRICE $249.99 YOUR PRICE $219.00 ( DSP controller / bass knob / preset selector )
STINGER ROADKILL EXTREME (CASE).............MAP PRICE $195.00 YOUR PRICE $179.00 ( 9 sheets is 36 SQ. Feet / 18'' X 36" Per Sheet )
STINGER SERIES 8000 PREAMP CABLES........MAP PRICE $451.00 YOUR PRICE $320.00 ( 4 Y-Adapters, 5-3' 2 channel RCA from DSP to amps )
MATERIALS..........................................................YOUR PRICE $150.00 ( Wood, mounting steel, fabric,ring terminals.....)
JL AUDIO 10W3V.3-4 (4).......................................MAP PRICE $1199.96 YOUR PRICE $1035.00
** O R **
JL AUDIO 10W6V.3-D4 (4)....................................MAP PRICE $2399.96 YOUR PRICE $1990.00
_____________________________________________________________________________________________________________________________________________
FOCAL PS165V1.................MAP PRICE $519.99 YOUR PRICE $419.00 ( Rear door 6.5'' woofer w. 1'' tweeter in factory locations )[/QUOTE
Where is the factory amplifier located? Is it near the rear subwoofer location?
thodrinsky
Hartford, CT, USA
Does anyone know where the factory amp is located in a 2021 ST?
Bunker Hill, WV, USA
Did covid kill frostbitebox? Can't find a website for it.
Sent from my SM-G986U using Tapatalk
Long Island, NY
Yes, they unfortunately went out of business, Bruce the owner was a stand up guy
hughes18
Campbell, CA, USA
My set-up:
** O R **
Did you use the wire from the factory speakers? Im installing a similar build. Where the amp is at? to instal the Zen Nav
