Has anyone put an LSD in the front diff and/or changed gear ratios?
Los Angeles
2003 Mach 1
Hey guys, new member to the boards here. I've done some searching and I found the rear LSD swap thread here/read the whole thing:
https://www.explorerst.org/threads/explorer-st-timberline-part-swap.2948/page-5
but I can't seem to find any info on anyone doing an LSD in the front diff. I'm wondering if that is a thing or if no one does that. I would imagine buying a second timberline LSD unit and swapping the guts into the front diff would be the path of least resistance to getting a mechanical LSD in the front diff?
Would changing gear ratios be as simple as swapping a new center section and ring/pinion gears on both diffs and then updating the ratio in the ECU? Not sure if anyone has done that yet?
Also, related but the eLSD is just basically traction control using the brakes and maybe fuel cut to the motor to attempt to get different wheels to grab vs just having an actual mechanical system to actually distribute the force to both axles right? I haven't read up on the eLSD. I should probably research that more.
It’s a welded rear differential so you’d have to do a full replacement basically, not as easy as just swapping the guts. If you have AWD, a LSD isn’t going to make much a difference, why no one has seriously gone further with any of it. The e-lsd yes uses the brakes.
A
Los Angeles
2003 Mach 1
I am aware of the welded in ring gear on the spool and the oddball gear ratio. I was thinking of sourcing some 8.8 posi spools and putting 3.55 gears in front/rear. Not sure if the juice is anywhere near close to worth the squeeze though. I know about the timberline swap as well. I guess what has me puzzled is why Ford felt the timberline should get a mechanical LSD in the rear diff if the eLSD works so well?
Selling point is the main thing is my guess. No one is off-roading enough in a platform like this for it actually to help. Also, Torsen diffs usually don’t like being launched on anyway, so it’s better we didn’t get it.
