RWD 2025 ST 0-60 with Ford Procal Video
I recently installed the Procal tune and after a few runs, just about the best it is going to launch on the street. Roughly 4.7 sec (original video footage of mine, 2.22 to 6.95 sec) leaving at about 1500 with little to no boost as it will blow off the tires. Slight spin as the boost creeps in , spun on 1-2 shift, and barked the tires on 2-3.
I am sure all will come running saying "you should have got AWD" but know that I am rarely launching my vehicle. This was purely a challenge for myself and I am not lining up at street lights or running from a dig. I live in SWFL and have no need for an AWD thus the reason for grabbing a unicorn when I found a RWD with no roof on the lot last year.
CVFAB intercooler and charge pipes are waiting to go on and likely will do some colder plugs as well.
Earth
Volkswagen thing
I like, wish they would release it for the 26my.
JFam
Yeah, not sure why they are always a year behind.
Carb certifications take forever.
Fort Lauderdale, FL, USA
How much better does it drive with the ford tune? Does it sequential shift? Or still do its silly stock shifting patterns?
JFam
My ST has never skipped shifted and always went through all gears whether in Normal or Sport. I hated it as well with my Raptor and Expedition.
The Tune improved firmness all around as well.
UAE
FORD EXPLORER ST 2024
Awesome RWD launch! Love how the rear tires bark on the gear shifts.
I have a '24 ST with 4WD, so unfortunately I won't be getting those tire spins on the launch like you do. I also ordered the Ford Performance ProCal 4 tune. By the way, are you running that on the stock intercooler, or have you already upgraded to an aftermarket one?
UAE
Right now, my Ford Performance ProCal 4 is on its way since I live overseas. But if I'm not happy with it, I'll most likely swap to a ZFG tune, which comes so highly recommended around here. To be honest, I kind of regret ordering the ProCal 4 now, because from what I understand, the ZFG tune is way better than Ford's factory calibration
Unless they changed something on the 25-26 models the transmission shifting has always been an issue among the drivers. When your flooring it, it typically shifts sequentially, but under normal daily driving it utilizes its own pattern.
JFam
Again, my ST from day one never skipped shifted. Maybe it is a RWD thing or something with 2025+, but I am very familiar with the shift pattern and horrible skip shift again dealing with it on multiple vehicles and over 100k miles of driving between the two. Light throttle in normal mode pre tune still went through all the gears.
JFam
Thanks. Regarding the Procal, yes, it is my understanding the the Pre 2025 tunes were very mild. When i saw the addition of 100tq alone, I was sold being I knew that addition being very similar to what the Roush Perf. Pack for my Raptor was and near that same number.
With the 2025 , you hear turbos spooling and as you mentioned, the shifts are firm barking the tires. Again, I know that it does not compare to the great tuners out there and leaving a lot on the table still.
With all due respect, It doesn’t always go:
1 → 2 → 3 → 4 → 5... etc​
It still skips gears whenever the software determines that's the best choice. You might not notice. But it will rarely ever go 1-10 in order every gear under normal driving. The first few maybe, but not every gear, every time.
Respectfully
JFam
Respectfully
Skip shift is usually 1,3 5, ....etc under normal / light throttle. That never happened but if we are talking about cruising through a neighborhood or parking lot then yes, it is obviously going to the most passive gear.
EDWYER
You should have got AWD. :LOL:
JFam
In a year of driving , it has never been needed here in SWFL. 150-200lbs lighter and being a base ST RWD with no options, saved a ton when buying as well. I am very happy with my mutt RWD.
Well we’ve come a long way from “it never skip shifted” to “yes obviously it skips” lol
alright cool, that’s all I was asking. Thanks bro
JFam
Thread Starter #18
I stand by my original statement as during normal / moderate accel, the 10spd never skipped in Normal mode going 1, 3, 5 like my Raptor did, Expedition or even my 2018 mustang with at 10spd. These were all pronounced rpm changes and then with any throttle push, commanded a down shift.
Mine when leaving a light and accelerating light throttle, when through sequentially with RPM's dropping a couple hundred until speed reached and .....then is passively chose the final gear. I guess one could identify that as "skip shifting". My Expy and Raptor would be in third before I got through the intersection and that is my comparison.
If you were talking about very slow speeds with little to no acceleration, of course it was not going to hold gears unless in manual mode.
