This car is great except….
Endicott, NY
2025 ST Line
Found this forum while looking for answers. I went to change the oil at 15,000 miles and after taking off the sound panel, I saw this. The last place to change the oil was the dealer when I bought it last year. It had 5000 miles on it. What I can understand is why I’m looking at all these reports of a plastic pan failing, but this is aluminum and that’s a crack. Obviously I didn’t try to loosen it. What oil pan is this? It almost looks like part of the block to me…a big expensive broken piece of aluminum. Speaking of which, today was my first time crawling around under it. Now I know why it’s such a rocket. Everything is lightweight including the aluminum control arms. I’m hoping the dealership dies the right thing, but I’m curious if anyone else has seen this. It’s hard to believe that the drain plug cracked it kind that unless someone went at it with an impact wrench. Others than that, this is one nice car. Is that a good intro lol :) any input is appreciated.
Get a pic from further away for reference. That’s awful straight for a crack…are you sure it’s not a casting mark?
Massachusetts
2023 ST
Looks like a casting mark to me as well.
Fenfab is the only one that makes aftermarket aluminum pans for these cars, and that doesn’t look like it. Like the others said, better pics would help. Also, that’s way too long between oil changes. You should be doing it every 5k miles or 6 months.
