Hood closes hard
Shepherdsville, Ky
2025 explorer st, hood very hard to close
Does not close when dropped. I have to push it down and back at same time to close
Farmers Branch, TX
Yeah, it does that. I let it drop, then give it a good shove to close it all the way.
Pushing on it is a good way to dent the hood. You should just be dropping the hood and it should lock. Adjust the bump stops.
B
Shepherdsville, Ky
Think I am going to let the dealer make adjustments when I scheduled the recalls
Mobile, Alabama
2025 Explorer ST 4WD
I give mine a decent drop distance, and it is fine. These aluminum hoods need more height.
All you have to do is screw the bump stops down by hand. No tools needed and most certainly no dealership needed.
B
Shepherdsville, Ky
I know that but if I adjust the stops then the hood will drop lower than the fenders
Not if it’s forcing the stops to compress more then they should.
Davidson County, NC
I adjusted the bumpers so that the hood is perfectly flush with the fenders. I drop the hood from maybe 5” and it locks every time.
Mobile, Alabama
I adjusted the bumpers so that the hood is perfectly flush with the fenders. I drop the hood from maybe 5” and I locks every time.
That's what I did when I bought it. The driver's side was sagging too much. I do drop a little higher than that.
