Is this knock behavior normal
FastDADst
Doctor
Medford nj
Explorer st 2025
Hi, everyone wasn’t sure which thread to post it in. Mainly was not sure whether the following would be considered normal or trouble?
just looking for some objective feedback.
Current vehicle is explorer st 2025 with around 11,000 miles on it.
OBD Link MX plus with FORScan Lite was used for the logs posted.
I am seeing Knock RET values varying from 2 to 4.5 seen once and mainly when the RPM is over 5000
I am wondering if 2 to 4° knock correction is considered normal on stock? Do these values look like normal ford correction strategies? Is there something
else I should be looking at or considering?
currently will attach pictures. I did not realize those files cannot be uploaded here. I am still learning. Will attach the appropriate files the appropriate way
F
FastDADst
Doctor
Medford nj
Explorer st 2025
Oem intercooler , 93 octane shell / 94 if I can find it but try to ensure it’s top tier
New Orleans, LA
Not Yet
@FastDADst
It's not really an apples-to-apples comparison but, looking through some of my old logs with a CVF IC your knock correction numbers are in the normal range.
If E85 is available in your area, you could try adding a few gallons to see if the numbers improve.
