2027 Ford Explorer Order Guide
DanMc85
New England
N/A
Panoramic Vista Roof and 3.0 for Platinum are back!!
Interesting highlights for me
  • roof rail delete returns for ST, ST-line , Platinum and active
  • 3.0 Platnium returns
  • Opening sunroof returns
  • ST sinister package
  • Avalanche grey and ruby red paint added
  • Illuminated ford badge
One thing that stood out to me in the ordering guide, unless someone made a mistake.
Is that for 2027 they may be body paint matching the lower bodyside cladding that goes along the bottom of the SUV and around the wheels and such instead of that black plastic trim.
They removed it from the Black section in the Ordering Guide.
Again, it wasn't called out in the 2027 changes list, so it could be a mistake or perhaps not?
Also, the 2027 is gaining the Open On Approach Rear Liftgate instead of manually having to push the button.
From what I read it works when the driver is within 3 feet from the rear lifting door and as long as the ultrasonic sensors in the bumper don't sense that it is too close to a wall or another thing it can hit.
YouTube Video:
The 2026 Ford Explorer ST is a BETTER performance SUV than an Acura MDX Type S
Its like Ford watched this video, around 4:22 minutes in, a handful of stuff the reviewer complained about is changed for 2027.
EDWYER
Interesting!
New England
N/A
Ford will not let you order the ST Sinister (which has the amber lights by default) package with the light up Ford Emblem. It is an invalid combination when placing an order ( Ask me how I know :) - This fall will be fun) . Also, the Ford Emblem is a dealer installed accessory post-delivery so it wouldn't come on the vehicle already installed before it hits the dealership. However, there is nothing stopping you from adding the light up logo yourself after the fact, Ford just won't sell it that way if you get the Sinister package.
Nebraska
The Sinister package seems way overpriced to me. As noted earlier in the discussion, the wheels are simply the Platinum Ultimate Package wheels painted black, so no new design, with the same tires the ST already comes with. The daytime running lights already have the amber color for turn signals, so just a programming thing on Ford's part (and probably doable in Forscan), and the badge is a very minor change that also should not cost Ford much if anything and could be done after purchase. I saw a video that shows that the base model Active has amber running lights as standard, so most likely changeable with Forscan. Basically you're paying for black wheels.
Massachusetts
2023 ST
#26
Agreed.
I can see the wheels adding a little cost. While they are the same wheels as the Plat, Ford probably incurs a small cost to make a limited batch of them in Black likely in smaller numbers, but would need to see Ford's accounting numbers to see how true this is. It's offset by the cost credit of the standard 21" wheels however. The Amber DRL's are likely a ForScan change, and the badges gotta be what? $50-75 tops? Profit maker for Ford right there as I can see that package being popular.
If the Active also has Amber DRLs, that sorta waters down the package IMHO as it's no longer a differentiating feature on some ST's.
But just my opinion.
Speaking of badges, can't wait to find out what the P/N is for them as I like the red badging, but would prefer the black surround vs chrome. IIRC, the 25+ ST badges are compatible with 20-24, but reversed? (Grill badge is liftgate and vice versa)
Nebraska
What's ironic about it is that the wheels and badges are probably cheaper to make for the Sinister Package as they would require less finishing work during manufacturing. The Platinum wheels have a mixture of paint and polished surfaces, while the Sinister wheels are painted all black. And the chrome on the badge needs to be added to the black plastic while they just eliminate that step on the Sinister badge. Definitely will be a money maker package for Ford.
Massachusetts
2023 ST
Right, but I was thinking about it from the perspective of economy of scale. I'm in manufacturing, and a simpler process doesn't always equal cheaper if the volume is less
But I can only speculate so you could be correct.
Nebraska
This is what irks me about the ST-line every time I see one. It looks so much like a true ST that I have to take a 2nd look to see that it isn't. Other than the ST badge on the grill and tailgate, and the quad exhaust tips, it is very hard to tell the difference. Talk about watering down the ST and its exclusivity, at least in looks.
Boston, MA
Agreed.
I’m definitely going to order the Sinister ST badges for my ‘23.
BuckStrickland
West Virginia
#32
#33
Looking forward to getting the wheels down the road.
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
#34
They could do so much, and this is what they give us? lol.
Give me Brembos. Give me Recaros. Give me PIU Shocks.
@BuckStrickland and @Mustang5L5 :
Those would be great but I would settle for returning the ST to its 2023-2024 glory and ADD a 3 Pack of oil temp/oil pressure/boost guages.
#35
They already offer them via Ford Accesories.
Massachusetts
2023 ST
#36
My guess is this is just lipstick on a pig (don't take that literally i like this chassis) to add a few low-cost tweaks through the end of the model run.
I imagine any good performance enhancements will roll out with the new chassis (whenever that is).
