Exhaust pipes between Cat’s and Borla Cat-back exhaust…
Midwest
Need some advice… looking to add the Vibrant Ultra Quiets to my exhaust but would like to start with new pipes between the cat's and the cat-back exhaust. A muffler shop replaced the factory flex pipes due to rattling, but they were really cheap quality and disintegrated so badly in two years you could clearly see the spring inside. They cut them out and replaced them again (another hack job) so want to start fresh.
That being said, does anyone know If there is an aftermarket replacement pipe with good quality flex pipes that I could cut a section out of and add the Vibrant Ultra Quiets too? If I have to use factory pipes, I can do that but, couldn't find the part number to purchase them. Looking to mimic the setup that Unbroken showed in his thread... I am running the Fenfab Catted Down Pipes and the Borla S-Type Exhaust. Any guidance is greatly appreciated!!!
-WickedST-
Midwest
Is it the same size as the factory piece?
-WickedST-
Midwest
Unbroken, is this the one you are talking about?
-WickedST-
Midwest
Also, based on using the above mid pipes, would I want to order 2.5” Ultra Quiets or do I go one size bigger to get them to slip over these pipes?
My 2.5 resonators slipped right my thermal 2.5.
