2026 ST what intake?
50CalLabz
New York
2026 explorer st
Hey guys I’m looking to get an intake for my 2026 ST. I see a lot of the companies on their sites only go up to 2025 as an option. Are these compatible with the 2026 and if so which do you recommend for my year? Thank you!
Gulf Breeze, FL
26 Explorer ST, 21 Bronco, 24 Ranger Raptor
I installed the SB intake on my wife's 26 ST. It fit perfectly.
EDWYER
It will come down to what you intake looks best to you in the engine bay.
Yes they’ll be compatible with your 2026. I’d go with the open filter intakes, they’ll sound great while the closed box variants are purely for looks.
Combatvet
I really dig the FENFAB V2, but be aware you have to buy the extra plumbing to avoid the CEL code that pops up from time to time. The sounds though, very nice.
Catmonkey
Louisiana
What is this "extra plumbing" you're referring to?
STTuner
United States of America, Utah Orem
2025 Ford Explorer
Most of the 2025 kits should fit the 2026 just fine since there really haven’t been major changes to the engine setup on the Ford Explorer ST. A lot of companies are just slow updating their site compatibility lists.
I’ve seen a lot of people run the AFE, FenFab, and K&N setups without issues. Just depends if you want more sound, better airflow, or something closer to OEM fitment.
The ECUs on these cars are a little finicky with the dual filter open intakes, so there was a fix for some codes by doing different plumbing for the vacuum hoses to fix it.
BuckStrickland
West Virginia
You'll get a lot of mixed opinions here, and honestly, up to this point, unless you're really maxxing things out (aftermarket turbos, fuel system, etc.) you're not getting a ton of difference in performance variation from one to the next. Pick the one that you think looks the best and or sounds the coolest, and send it. I personally really like the FenFab, but I've had SB products in the past, and I have some CT Motorfab things now, and they're also quality parts makers.
This. Pick anyone OP, cant go wrong with any, only wrong answer is K&N haha
I threw in a Green Filter 7035 and called it a day.
TX
Hello AutoFanatic43, my name is Mike and i have also purchased a CAI for my 2026 Explorer ST but i do not have the tool to remove one of the hoses needed as my kit did'nt come with one. Do you know where i can buy the tool needed in the attached screen shot or would you mind selling or just even sharing the tool as i cannot find that tool anywhere.
Cut the hose around the connection, and then just pull it off. When you go to reattach it just use a worm clamp to connect it back onto the connector.
Gulf Breeze, FL
@2020FordRaptor is correct. You can cut the hose, or that orange connector, and reinstall with a different clamp. My intake came with the tool that is pictured, but it didn't work. If I remember correctly, the intake kit came with a new hose connector for that fitting.
There are a few good videos documenting the installation as well.
I'd be happy to send you the tool, if I can even find it... but it's really not necessary.
