Lubbock texas
2021 ST carbonized grey metallic w/black leather
Tires are on. I’m not in love. My Pirelli 315’s were a much better fit. These Yokohama’s are WIDE. They’re a bit too far past flush for my taste. I’m gonna put a few miles on them but it’s highly likely I’ll go back to 295’s shortly. View attachment 35272
BUMMER
Thread Starter #1,502
V2 of moving my vent gauge to a blue cruise sensor is done. I dig this one. IMG_0443.jpeg IMG_0444.jpeg
25SWST
El Paso
Looks damn good
Thread Starter #1,504
After I cut the floor in the back, I couldn’t use the factory belly pan thing anymore because it blocked the vent. I tried cutting some holes in it, but it was still making noise when the stereo was playing. I removed it and then the back bumper is all floppy and weak so I finally got off my butt and drew up a new air deflector to lock everything down tight again. I made this from .050 aluminum in our fab shop today.
Thread Starter #1,505
Well these 315’s are just absurdly wide. Yokohama definitely gives you your moneys worth. lol
I decided to try out the Atturo AZ850 back in a 295/40…lots of good reviews and not bad on price. Higher speed rating than the Lionharts in the same price range too. I’ll throw them on later this week. IMG_0560.jpeg
I decided to try out the Atturo AZ850 back in a 295/40…lots of good reviews and not bad on price. Higher speed rating than the Lionharts in the same price range too. I’ll throw them on later this week. View attachment 35476
If you happen to road force I’d be curious the results prior to correction. Thankfully the Explorer is not very sensitive to road force but once over 30 lbs it becomes pretty noticeable.
Thread Starter #1,507
Added the new radiator shroud from Josh at horsepowerfabrication.com today…first one off the press. Fit and finish is perfect. If you wanna hide that ugly spot this is the right tool for the job. IMG_0607.jpeg
Midwest
Damnit Unbroken!!! You keep making or coming up with all of this cool stuff that I didn't know I needed... If you end up making the tinted cover for the Blue Cruise pod let me know, I would buy one from you.
Thread Starter #1,509
I actually should have a CNC’d prototype at the end of next week if I have time to go get it.
Thread Starter #1,511
Back on 295/40’s. These things are smooth as glass so far. The right rear actually doesn’t have a weight on it at all…it was perfect as-is. I’ll withhold judgment until I get some more miles on them but so far mildly impressed. IMG_0629.jpeg
Montréal
Sweet…. Thanks to you I am using the same setup. I always wondered how Ford racing used 315’s on their ST
Thread Starter #1,513
Tires vary widely when it comes to measured width versus advertised. I had Pirelli 315’s on here several years ago that fit perfect. They just cost too much and wear too damn fast to use them again. These Yokahamas measured somewhere between a 325 and 335.
Montréal
Also noticed you’re not using front splitter anymore…. Was it scraping or something?
Thread Starter #1,516
Nah…just got tired of it. I took the side skirts off several months ago too.
Montréal
Ah ok, I noticed those couple of months ago…
