Guide - Fixing AWD module ground.
Cedar Park, TX
2020 Explorer Platinum
+1 Signing up to say thank you for the guide! It helps provide some context for the Ford TSB. I'll provide some notes from my install.
Removing the driver seat is not that hard and I think worth the effort. I also tried reseating the connector first, but it only cleared the codes for a day or two. I had one mounting nut on the module that was not grounded, tightening fixed that. My pin 46 was not connected to ground at all when I tested it (I am assuming this was the major issue). To fix it, I removed the back housing of the connector but did not bother removing the red locking block or depinning the ground wire. I simply cut the black and white wire from the harness and used a waterproof butt crimp to connect the new ground wire. My guess is Ford tells you to depin it to make the crimping and heat shrinking safer/easier but I didn't find it necessary. Soldering would obviously be better if you have the skills and want to take the time. For the new grounding point I used an M6 tap to tap threads into the hole as the first bolt I tried completely stripped out.
SpceSpff
U.S. Coast Guard Veteran
Firefighter
MTZ
2020 Explorer XLT
Well my fix lasted 3 days. Will tear it apart tomorrow and do this TSB.
FEbob
Middleburg, FL, USA
Background:
A common issue in these cars in the 2019-2021 build date is a failing ground on the AWD module under the driver’s seat. The metal enclosure of the AWD module is supposed to be grounded by 3 nuts to the body of the car. These standoffs are often covered in paint and in general are just terrible for a proper ground. This failure can be a completely failed ground which means there is an open circuit from the Case to the body of the car. This will cause some set of symptoms, primarily AWD module no longer responding or turning on at all. The failure can also just be an intermittent issue where the symptoms go away and come back occasionally. And finally it can just be that the case has a high resistance path to the body. In this last instance, a multimeter will beep in continuity mode from the case to the body indicating a ground Is present but the resistance is high. The hallmark feature of this issue is that the AWD module gets a lower voltage than all of the other modules. This last case doesn’t seem to be documented anywhere online except in my thread where I diagnosed the issue. In my instance with high resistance ground, it caused the brakes to occasionally fail to work after starting the car and putting the car in gear. VERY SCARY FEELING. Also, I got various frequent ABS codes and random modules failing to respond or getting invalid data. The most worrisome codes it may cause is “transfer case current low” and “transfer case clutches slipping” and “transfer case actuator current low” and “general electrical failure” from the transfer case. And in the ABS module it would report that the transfer case module stopped responding. Every time I scanned for codes i had some different variation of the DTCs.
Diagnosis and Identification:
If you can use Forscan on a computer and log data live with the oscilloscope feature, this would tell you more. The AWD module needs to see close to 12V with engine off and 14v with engine on. If you see 8-10v with engine off or 8-12V with engine on, then you likely have a bad ground. Otherwise if the AWD module isn't being found at all in forscan then your ground might be completely failed.
You can put the drivers seat all the way forward and pull the carpet up pretty easily just enough to see the AWD module. Check continuity from the case to the body of the car. You should have 0 ohms resistance it should be a straight shot from ground to the body.
You can also try wiggling the connector on the AWD module to see if the ground clears up. That temporarily resolved my issues. I have read reports of people removing the harness and putting it back on and the issues going away. When logging live in forscan you can see the voltage correct itself when the ground is restored.
Known issue acknowledged by Ford:
Ford has issued a couple TSBs that i was able to find. Originally they issued a TSB to replace the modules when this happened. They were constantly changing them out and the issues would come back later. Then they discovered the grounding issue. So they issued a (seemingly temporary) TSB to remove the seat and de-pin the ground wire from the harness and splice in a new dedicated ground that terminated at a ring terminal to an M6 bolt in the body of the car under the seat. Finally, it seems to me that this TSB no longer exists anywhere in the Ford database. Now they just fall back to the original TSB to replace the modules but i’m guessing the newer modules have some updated provisions to handle the grounds better internally so it’s not an issue. Personally I don’t want to spend a thousand bucks for the dealership to replace the AWD module when it just needs a ground. So I performed the TSB to add a ground to the existing module.
My Guide for performing TSB 23-2061 for Adding Ground to existing Module:
The official TSB from ford (that no longer exists in their databases) is here: https://www.explorerst.org/attachments/ford-tsb-23-2061-pdf.31859/
things you will need:
the bolt from ford is M6. I used the official Ford bolt but use whatever M6 bolt you like. A 1/4” or M6 ring terminal, i prefer the heat shrink ones. Electrical tape. Some good quality wire. I opted for 14awg. I wouldn’t really go thinner than that. Hard to know what current is expected through it without measuring it in different scenarios. I haven’t smelt anything burning yet so I think 14 AWG should be good (; lastly, you need some way that you feel comfortable to connect this wiire to the ground pin of the AWD module. Honestly this could be as simple as another ring terminal on the nut of the AWD module mounting stud. But because I didn’t fully understand the internal workings of the module I opted to follow the TSB as close as I could. You might be able to get away with a tap splice to the ground wire. If you know the part numbers and know where to get the female pins for the harness that would be the most ideal way. I personally chose to solder the 14AWG wire directly to the existing ground pin. This felt like the best way in my opinion because it means you are not relying on the current flowing through the thin factory wire. But do whatever you feel comfortable with. I’m not responsible for you messing up your harness connector.
getting started:
Move the backrest all the way forward so it fits through the door. Then move the whole seat all the way back to expose the front frame bolts. View attachment 32000
then remove the plastic covers and unbolt. It’s 13mm.
Then move the seat all the way forward to expose the two rear frame bolts. Remove the plastic covers and unbolt. 13mm again. an extension will help.
View attachment 32005 View attachment 32004
now the seat is loose but there is two cables you need to worry about before moving the seat out.
before disconnecting the connectors you need to move the seat halfway forward so the frame rails fit nicely under the butt of the seat. This just helps you fit it through the door. Then disconnect the negative terminal of the battery so you don’t throw a bunch of codes for tampering with the electronics.
View attachment 32014 Under neath the seat up under the butt, you have a chunky connector. Press into the connector in the center and there is an arm you need to swing out once the center is pressed in. It’s pretty easy once you figure out how it works. View attachment 32007
that body harness is also secured to the seat with a plastic clip so you need to pry it out of the mounting hole.
the following cables look aftermarket and bunk as heck so I don’t know if you will have them… but if you do, cut all the zip ties and expand the cable to it’s full length. There is NO connector to disconnect here… thankfully my cables were super long so i was able to remove the seat still with it attached.
View attachment 32012 You’re ready to remove the seat now. Optionally you should be able to just push the seat back onto the second row if you fold the second row down. If you proceed to remove it entirely, Be careful not to scratch the plastic trim on the floor or the B pillar. Maybe put a blanket down! It’s heavy but doable alone.
expose the beam and AWD module under the carpet. Pull up that one plastic clip.
here you can see the terrible studs Ford relies on for grounding. You don’t need to remove the module but I did just to get a good look for the photo.
press this center tab and then swing the arm out. Pull the connector off.
this is the pin you will want to depin if you plan to follow my same method of soldering the 14awg wire to the pin.
to remove the red locking Block, it’s not too bad. Use a small flathead to get under the red inside the channel and pry it up. You should squeeze and apply hard pressure with your other hand to the outside of the black housing to help prevent breaking it when prying against it. I broke mine in a few spots but the connector still operates and locks on very good. So it’s not life or death here if you crack something. There are two little channels where you can put the flathead into and there is a good way to get under the red. Use those sides first since the other two of the 4 channels dont give you as mich of a ledge to catch with the screwdriver. It’s really not too bad i thought it was going to be a lot harder.
once you get the red block out, this housing comes off easy. Remove it by pressing this tab and pulling off.
to depin the black and white ground wire pin, its pretty easy too. In between the top and bottom pins you can see the little locking tab deep down holding it in. just pry the plastic tab away from the pin and pull the wire from the back and it will come out. You will want to cut and peel the electrical tape and wrap the factory puts on, expose as much wire as you need. This is how far i went:
i opted to save the red seal thing and just jam the wire through the center. I used a sharp spike tool i had and inserted it through the center and then fed the wire through after the spike. I dont think you need the rubber seal it just helps with corrosion and strain relief but this connector shouldn't see harsh conditions so do what you like.
Solder the new wire to the pin and keep the old wire there. Get it nice and hot, make sure everything is flowed nicely, dont leave a cold joint. Thankfully the connector housing gives you a lot of room for the extra space the solder and wire takes up.
insert the wire to it’s home in the connector listen for the snap of the locking tab, pull to make sure it is secure.
Press the Red locking block back in, it will snap nicely.
Now you want to just give the wires some slack and electrical tape up tightly back to the body harness make it look nice and this will help protect the wires at the pins. Then reinstall the housing and zip tie it on again. just put it back how you found it basically. Check the connection from the AWD module case to the wire you just added.
Then you need to crimp and heatshrink the ring terminal. Measure out how much wire you need and zip tie it in a few spots to the factory harness. You also need to sand the paint (and underlying primer) to expose raw metal on this beam. This is where you will insert your m6 screw and ring terminal. There was no threads in this hole for me but after screwing the bolt in i was able to torque it really well. View attachment 32031
now just clean up make sure you dont forget anything. Put everything back together in the reverse order of these steps.
Verify with forscan that the module is getting 14v with engine on and that the transfer case actuator is working. You can clear all the DTCs and verify they don’t come back. Enjoy the car! View attachment 32033
Thanks, this fixed all my problems on my 2020 Explorer ST !!!!
MTBBatman
Thüringen
2020 Ford Explorer phev ST
Hey guys,
I’m having some intermittent issues on my 2020 Explorer PHEV (EU-spec vehicle) and wanted to ask if this sounds similar to the known AWD module ground issue some of you had.
I randomly get warnings like:
- Hill Start Assist Not Available
- ESC Failure
- Pre-Collision Assist Not Available
The warnings only appear right when starting the vehicle and disappear again after 1–2 seconds. However, even after the warnings disappear, some related systems still stay unavailable until I restart the vehicle again. For example, if I put the car into reverse after the fault happened, I consistently get a message saying that reverse brake assist is unavailable.
Once I restart the vehicle again, everything usually works normally.
Also, even if the fault literally just happened, I can clear the codes immediately and they usually do not come back right away.
To me it almost feels more like some kind of communication / initialization problem during startup rather than an actual hardware failure.
I scanned the car and it shows a U0102 communication fault with the transfer case / AWD module.
At first I thought the 12V battery was the issue because it was often around 12.0–12.2V after sitting overnight. Today I got a brand new battery from the dealer, but the problem still came back afterwards.
What’s strange is that I have absolutely no issues while driving:
- no AWD faults
- no drivability problems
- no permanent warning lights
Right now I unfortunately don’t have Forscan available, so I can’t do any further testing yet.
Did any of you guys with the AWD ground issue have the same startup-only behavior? Or does this sound more like a different issue?
Thanks!
W
Nunya
Thread Starter #25
Hey guys,
- ESC Failure
- no AWD faults
Thanks!
If I had to guess, this is probably an AWD ground issue. How are you clearing codes? Are you clearing them with a scan tool or are you just pressing “ok” on the steering wheel? Are you able to switch between the different drive modes? Sport/normal/eco etc?
Forscan is helpful but you might be able to just check the AWD module voltage another way as well. For example do you have a FADA on the front left axle? There is a connector on it that you can check the voltage and ground on and it should match what is on the AWD module under the seat.
on American cars the AWD module is under the front left Seat. I don’t know if they would move it for right hand drive cars or not. But you can try grabbing the connector and wiggling it to see if you have any change in behaviors.
MTBBatman
Thüringen
#26
As for the FADA, I’m going to check that today as well. Where exactly is it located?
W
Nunya
Thread Starter #27
The quote reply showed up weird for me but the response i saw is:
It is under the car near the left front axle. It is called a Front Axle Disconnect Actuator. The connector is towards the front of the FADA if I remember correctly. Wish i could remember which pins are which but there’s only 4 pins so it’s not hard to figure out.
You should expect voltage to be ≈12v with car off and ≈14v with car on. Disconnecting it while the car off and keeping it disconnected with the car on wont hurt but it will make your dash alert with a ton of warnings FYI.
Check that there is no resistance on the ground pin to the chassis. If you have trouble finding the ground pin and the voltage pin or if the ground pin has low voltage on it or high resistance to geound then you probably do have the AWD ground issue.
MTBBatman
Thüringen
This was my first response:
As long as the fault is active I can’t switch between the drive modes either. Sport/Normal/Eco etc. are unavailable until I restart the vehicle again.
I’m clearing the codes with an Autel diagnostic tool, not just by pressing “OK” on the steering wheel.
Besides the U0102, I’m also getting:
- U0100 (Lost Communication With ECM/PCM)
- U0111 (Lost Communication With Battery Energy Control Module)
The car is left hand drive and the AWD module is indeed under the front left seat.
Yesterday I also checked the AWD module ground against the chassis with a multimeter and everything seemed fine there.
Although I just thought about it and could be the issue that even if the chassis of the awd module has good ground the internal components don’t?
W
Nunya
Thread Starter #29
Yes these symptoms do seem a little different than what i personally saw. The communication errors tend to be kind of random and caused by low voltage. For example i had communication errors pop up with the steering wheel controls.
It kindof makes sense that startup could cause issues that go away quickly. The voltage can sag briefly during starter cranking.
Does this happen on every start? Or intermittent and random? You could try starting it every time with a jump pack or jumpers to see if the higher voltage makes a difference. If it does then it could be more likely to be an electrical issue. I have heard of the transfer case failing and causing similar issues. Have you seen any other errors related to transfer case? Like “transfer case actuator out of range”?
It could also legitimately be a failed AWD module that needs replacing but my running theory is that they don’t really fail- they just have bad grounds. It could be that there is a bad internal ground like you say. I really am only speaking from my personal experience with my car and from the tons of threads i have read online. Someone in this forum is selling an AWD module. can you do the module relearn procedure with the autel scan tool?
MTBBatman
Thüringen
#30
Thanks, that actually makes a lot of sense.
Last night I checked the 12V battery again and even though it’s a brand new AGM battery, I was only seeing around 12.2V after the car had been sitting for 1–2 hours.
I left it on a charger overnight, but I only have a small motorcycle charger, so it probably didn’t charge much because of the low amperage.
This morning the fault came back again on the first startup after the car had been sitting overnight.
It doesn’t happen every time I start the car, but it definitely seems more likely after the car has been sitting for a while.
I also don’t have any other fault codes besides the U0102, U0111 and U0100 communication codes.
The car is still under extended warranty, so in the worst case I could probably have the module replaced through Ford. But since the Explorer is pretty rare here in Germany, most Ford dealers don’t really seem to have much experience with these vehicles or with this specific issue.
So right now I’m still trying to figure out if this is mainly a low voltage/startup issue or if it’s related to the AWD module ground issue.
#31
The recall is for modules that aren't properly chassis-grounded. You'll note the recall is not to add a ground to the chassis, it is to add a ground to the harness of the module. Just go ahead and do the TSB if your Explorer falls under the recall date.
MTBBatman
Thüringen
#32
Yeah I’ll probably do that.
what’s weird is that on all forum post‘s I’ve read there’s almost always some problem with low voltage. I just downloaded Forscan and looked at the awd module voltage.
i‘ll attach 2 pictures. 1 with the fault codes showing up and the other without.
W
Nunya
Thread Starter #33
Can’t see the axis on the second photo to tell but what is that drop in voltage towards the beginning of the plot? How low does it drop? Is this with engine running or engine off?
EDWYER
#34
@MTBBatman Check this out.
magnews
Norway
I can't believe it! Another one just signed up just to give praise from across the pond, this time on a 2022 Explorer PHEV. I've had false positives before, seemingly because of bad grounding and it "sorted itself out someway" but today it stuck even after clearing. I was going for an overtake on a very wet two-lane road, and as I stomped the pedal I discovered that the ESC and stabilisation-systems errors surely was real: I lost traction in the rear and drifted sideways on the highway going about 60 mph. After two major, lockout turn radius drifts in each direction, I managed to get her under control and straighten up without touching other cars or the railing. I almost needed new underwear afterwards!
After diagnosing with ForScan and chatting with Claude, this guide was all I needed to diagnose and confirm the issue, as well as getting it sorted. The AWD-module reported 2-3v short of system voltage, sometimes even dropping to 6-8v. The wiggle-test confirmed the issue, and when starting the car after wiggling to cable to the correct position, no error codes were thrown. I decided to go for the proper fix, seeing I had this detailed guide at hand. Three hours later, I was back on the road with a AWD-module measuring 14.5V like the rest of the system. My car is out of warranty so I'm just amazed that this was possible to fix with some elbow grease.
Thanks to guys like you, ordinary guys like me can walk around feeling like they're gods amongst men, gods who can fix their own stuff! All the best from Norway!
W
Nunya
Thread Starter #36
Glad you didn’t crunch her up, glad you’re safe! Scary stuff. So happy I could help. Thank you for sharing.
Suprawill1
Just did the pre test, checking the continuity between the module casing and the floor where it's mounted. There was zero resistance.
I did put the second probe on the bare metal threads where the seat bolt secured.
I don't have forscan so next time I have the seat lifted, I'll test the voltage with a meter if I can find the right 12v wire to the module.
What's weird is, I seem to have a second wire harness coming from the connector that has twice as many wires as the harness shown in your pics.
Funny thing is they're completely chopped off at the other end about 4" from the connector and have some drip on insulation at the ends.
I have the same problematic symptoms:
Hill Assist Not Available
Pre Collision Assist Not Available
There are others I'm not remembering at the moment but just recently, something about the 4 wheel drive came up. When it does, I get the wrench icon and most of the functions I use, get disabled.
Something else that has returned is also a problem. The alarm will start going off. When that starts, it goes off every 10 minutes. I've gone out and slammed all the doors, recycled starting and was about to pull the battery cable when it finally stopped.
W
Nunya
Thread Starter #38
It looks like a previous owner did you dirty. I don’t see any reason why that would be there from the factory. Sorry to hear this. Sounds like it needs to be fully gone through and restored to factory.
Suprawill1
Right?!?
It didn't pose a problem until recently. I've driven it almost 2 years of the 3 I've had it without incident with the exception of having to replace the front struts and a starter.
Looking at many other cases, I don't think any of the mods I did created any problems.
EDWYER
#40
That is strange.
Seems that way. Never know what you may find.
