2025 Grille replacement
Greenville WI
I have a 2025 ST and someone or something broke off the ST emblem and the pieces to attach it, from the front grille. It seems like the only you can get the pieces to attach it is to replace the grille. Does anyone have the procedure to replace the grille. I can only assume, the entire bumper cover will need to be removed, correct?
Remove the bumper cover, and then it mostly just snaps together. Maybe some little torx screws here and there depending on how far you strip it down.
There’s a guy that makes a 3d printed mount for the ST emblem on Facebook.
Massachusetts
2023 ST
Seems to be a common issue on the '25+. Or at least might be becoming one.
I've seen a number of folks complain about this same thing on the FB groups.
Virginia
2026 ST
I'm not taking mine off but if it goes missing I'll just leave it off.
