Battery while tuning
Jacksonville, fl
2021 Explorer st
Morning, looking to tune my ST. While uploading the tune should i leave my trickly charger hooked up to the battery? I have a noco 10 genius.
https://a.co/d/02LVI7LR
Many use a charger with power supply mode for flashing tunes. This one is inexpensive compared to the more expensive ones, like Schumacher DSR Pro, which I use if I'm flashing a bunch of modules using FDRS.
I’ve flashed thousands of tune files across who knows how many vehicles…never once have I or anyone I know used a charger.
Can’t hurt.
You do not want overvoltage or AC ripple voltage. Either charge your battery before you flash or use one with a power supply or flashing mode. I wouldn't be flashing with a trickle or regular charger attached.
Mobile, Alabama
2025 Explorer ST 4WD
Its fast with the ZFG kit, no need.
Curious...how fast approx? With Livernois, I feel it is a good 5min or more.
Mobile, Alabama
Curious...how fast approx? With Livernois, I feel it is a good 5 minutes or more.
I do all of the uploading and downloading at the PC first. You plug it in and connect the app, and I'd say the tune loads in about 60 seconds.
