Battery while tuning
jameszi
Jacksonville, fl
2021 Explorer st
Morning, looking to tune my ST. While uploading the tune should i leave my trickly charger hooked up to the battery? I have a noco 10 genius.
https://a.co/d/02LVI7LR
Many use a charger with power supply mode for flashing tunes. This one is inexpensive compared to the more expensive ones, like Schumacher DSR Pro, which I use if I'm flashing a bunch of modules using FDRS.
I’ve flashed thousands of tune files across who knows how many vehicles…never once have I or anyone I know used a charger.
Can’t hurt.
You do not want overvoltage or AC ripple voltage. Either charge your battery before you flash or use one with a power supply or flashing mode. I wouldn't be flashing with a trickle or regular charger attached.
Genius 10 has 12V Supply mode (13.6V constant)... you are good.
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
Its fast with the ZFG kit, no need.
Curious...how fast approx? With Livernois, I feel it is a good 5min or more.
Gadgtfreek
Mobile, Alabama
Curious...how fast approx? With Livernois, I feel it is a good 5 minutes or more.
I do all of the uploading and downloading at the PC first. You plug it in and connect the app, and I'd say the tune loads in about 60 seconds.
