Metallic rattle from rear passenger's wheel well.
This one has been a challenge. 2025 8800 miles.
Rattle present for months, prior to suspension work. I thought it was the tools I had stored in the rear rattling but after removing the tools the rattle still existed.
Metallic rattle on passenger’s side rear wheel well area while driving over road irregularities. Sounds very loose, will rattle with the slightest road irregularity. Will rattle regardless of the weather or vehicle being hot or cold. Small road irregularities will cause it to rattle at a high frequency and large bumps will cause it to rattle matching the larger frequency. Please see photo for location.
Have checked (likely forgot a few) with no change, rattle still present:
Under vehicle-
Rear sway bar end links replaced with factory.
Rear shocks swapped side to side. Removed rear shock on passenger’s side and road tested, no change.
Checked torque on control arms and links.
Checked for interference and rattles from AC lines.
Checked fasteners for AC lines.
Checked spring isolator.
Removed fender liner, checked for possible cause.
Checked heat shields.
Checked wire brackets and brake line bracket attached to fender.
Exhaust hangers and general clearance.
Interior-
Removed panels looking for source.
Checked cavities in unibody for source.
Checked seat belt mounts and retractors.
Checked torque on everything in the quarter panel including HVAC housing.
Checked AC lines.
Checked third row seat bracket for possible source, no change.
Installed missing fasteners in the duct work.
Sounds like this, although gets louder at times. https://photos.app.goo.gl/23ro8PDENcNho71t5
The location of the sound is specifically identified in the photo.
Ideas?
MO
2026 ST AWD
I wonder if that joint needs (needed) seam sealer from the factory. Have you given that area (the wheel well, the panel on the well) the old light "palm strike"?
Great detective work by you. Pretty frustrating to have a rattle on a low-mileage 2025.
/edit/:
Is there anything in those channels?
The sound is very mechanical, "clicky". Suspension part is suspected because, as you said, the noise occurs with any change in the road surface. Brake component? Have you (gently) tapped stuff in that area with a rubber mallet? Yank up and down on the passenger side axle (suspension unloaded/drooped)? And, push/pull the wheel while the suspension is drooped? Something in the spare tire well?
/end of edit/
S
/edit/:
/end of edit/
Yes I have ran a mallet over nearly everything inside and out. I can rock the vehicle back and forth and nothing, only present while driving. I am not able to get anything to make any noise while tapping. I even ran a magnet inside every cavity I could find to see if there was any loose metal. I also ran a long zip tie into cavities to feel for anything loose. I even removed the shock and looked for something loose behind the threaded inserts in the body which secure the strut mount.
This one is a tough one, I am usually pretty good at finding these but this one so far has been challenging.
It is odd to have a loud knocking right in front of you at the wheel well then have no idea where it is coming from.
MO
2026 ST AWD
SugarMouth,
That's some thorough work! At least you've narrowed down the location. It's maddening that the source of the rattle remains elusive - for now.
I've seen a set of "mechanic's microphones" which would be placed on various parts in the rear PS wheel area that should go a long way to finding the offending item. Each microphone reports to the receiver and the resulting traces tell the story.
I'm sure you've looked at the muffler hanger bushing? They've been known to transmit noise into the body.
EDWYER
Just a guess- something is stuck/lodged behind that panel you pictured when it was manufactured.
S
Yes checked the hangers.
S
Hopefully not. There are areas where I have circled in the photo that have cavities, I tried to poke around from both inside the vehicle and through the upper strut mount bolt holes and did not find anything.
You sure that's not the undershield? Sounds just like that... tapping. You could swear it was inside the car but it's the shield(s) flapping. Have you gotten rid of all those plastic undershield retainers?
S
It’s a 2025 with metal nuts and no shield on the passengers side.
Kansas
2022 Rapid Red ST
A couple years ago I began getting a small tic sound over bumps from that area. For a while I could make it go away by engaging the seat belt although that no longer helps. For that reason I have assumed it may be something to do with the seat belt retractor.
S
Yes I focused in on the belt mounts and retractors. I even pulled the belt all the way out to put pressure on it.
After a ridiculous amount of time trying to isolate it, I found the noise is specifically in the area in the red circle and I believe it to be coming from outside of the panel.
it can vibrate with the smallest of road imperfections then not on others. Sometimes on large imperfections then not on small. It seems to be certain frequency vibrations.
It’s hilarious to hear it right in your face and not be able to find the source.
MO
2026 ST AWD
SugarMouth,
If you have a borescope (or a friend with one), it may be small enough diameter to fit down the gap in the two channels on the wheel well. I like your zip-tie method but seeing is believing (usually) so a borescope might show an offending piece of metal.
Have you used compressed air down those channels? Maybe enough air will cause the noise and that would confirm there is something in there.
"It’s a 2025 with metal nuts and no shield on the passengers side." <--- if the nuts are installed, how about putting an o-ring on the washer so there is no direct (rigid) metal-to-(rigid) metal (washer to body) contact. Just throwing spaghetti at the wall...
S
SugarMouth,
The air and borescope ideas are good ones, I have neither but will possibly source them at some point.
For S&Gs tonight I removed the Steeda vertical link insert hoping it was rattling but no luck. Back it went in. Spent another 40 minutes or so inside and out trying to find a source. I'm running out of ideas. The cavity where the sound comes from (circled in red) has a fastener for something but have no idea what because there are I believe two layers of sheet metal before the outer layer. When I ride in the back and listen it is concentrated right at the arrow but sounds like it's coming from the outside.
Denver Area
Wow amazing testing diligence. I have recently started experiencing the exact same clunking from the exact same spot. Mine is a 2020 with 90k miles.
Only similarity I see is that I installed a Sway bar last summer. Wondering if I didn’t get something tight enough. Or messed up the end link when tightening things back up.
S
My next plan is to see if the AC lines end up making contact with the rear sub frame as it compresses on the bushings. There are lines that travel over the rear subframe which I have verified don’t rattle. They do run pretty close to the subframe but are not making contact. My thought is the frame compresses up and makes a slight contact with the lines.
As with the 1,436 other items I have tried, I am not holding my breath but continuing to hunt until I find it.
S
Thread Starter #17
I believe I found the source. H&R spring dead coils rattling. Sound is gone when I isolate them.
MO
2026 ST AWD
Wow! Who'da thunk it? Excellent detective work, Sir!
Is the spring seated in the perch (that is, at the lowest point in the lower arm)? Are those coils making contact with something, or, is the spring itself making the creaking/groaning metallic noise? I presume that there is a warranty although you have to go through the effort to pull out the old springs and install the new ones.
Glad you found the issue. (y)(y)
S
Thread Starter #20
Spring is properly clocked and seated.
The dead coils are contacting each other. I spoke with H&R on the phone and they say they have not had any reports of this from our platform but this is not the case. It is rare but has happened. H&R does not have a solution for me yet and asked I wait for their response. I asked H&R why do they thing Eibach installs isolators on the Explorer kit and they were surprised and did not know. I think I'll reach out to Eibach and find out why.
I found some isolators but they are way under sized, they so far have held on but not sure for how long.
