Air flow upgrades
#61
In rear gear ratios, the higher the number the lower the gear, in turn helps with the launch. The diff is a Super 8.8, the Timberline had them as an option.
You have a 10 speed transmission which already does the job for gearing, all the fastest Explorers have stock gearing. All 2020+ Explorers get the super 8.8, just with different gear ratios. The timberline just got an Torsen limited slip and it was standard. Do you have AWD?
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #62
RWD, I'm spinning way too much on the launch.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #65
I already have everything that Steeda had to offer for the suspension
#66
So you have the subframe bushings, vertical links inserts, and toe links.
#68
Then I’d focus on getting a good tire setup.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #75
Kinda like posting your 2.3 in an ST group…keep telling yourself it’s fast.
Keep telling yourself you are Mr. Know it all and no one knows anything but you.
