Air flow upgrades
#61
In rear gear ratios, the higher the number the lower the gear, in turn helps with the launch. The diff is a Super 8.8, the Timberline had them as an option.
You have a 10 speed transmission which already does the job for gearing, all the fastest Explorers have stock gearing. All 2020+ Explorers get the super 8.8, just with different gear ratios. The timberline just got an Torsen limited slip and it was standard. Do you have AWD?
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #62
RWD, I'm spinning way too much on the launch.
#64
Suspension mods i would do next then. Or a better tire setup.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #65
I already have everything that Steeda had to offer for the suspension
#66
So you have the subframe bushings, vertical links inserts, and toe links.
#68
Then I’d focus on getting a good tire setup.
Your 2.3 Explorer is probably faster than that tank.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #71
Doubtful
All that to run 12’s. lol
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #73
If that's what you think. Keep telling yourself.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #75
Kinda like posting your 2.3 in an ST group…keep telling yourself it’s fast.
Keep telling yourself you are Mr. Know it all and no one knows anything but you.
That’s your projection as I’ve never said that. You just don’t like what I’ve said about your pointless mods so it’s a feelings thing for you. I don’t care about your feelings…or your slow cars.
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #77
It's not a feelings thing for me, you obviously do care because you continue to comment. At the end of the day, I did what I said that I was going to do, and you are ass hurt about that.
What did you say you were going to do? Join a group for cars you don’t own and run slower than a stock one? Yea…you definitely did that.
Co
2025 St
#79
C
ChuckD23
South GA
2023 Ford Explorer
Thread Starter #80
Thanks for proving my point
