Spark plug change
Sean R.
Western NC
Who had changed to a heat range cooler plug and who hard is it to the the plugs on the ST... Thank you for any advice.
It’s not too bad. Take the strut brace off for extra room. Pull the cover off the HPFP and toss it...it’s just a sound dampener and take the bolts out of the hard lines across the top of the engine so you can move them out of the way. After that it’s all standard stuff.
Sean R.
Sean R.
Western NC
Nice.. And thanks.
DChute
Jefferson City, MO, USA
What is the general recommendation for spark plug upgrade for the ST?
Dallas, TX, USA
There is really no need to take off the strut brace.
Las Vegas, NV, USA
Virginia
Hey guys, I was about to replace the plugs in my 2020 as they are the original with 50,000 miles on them. I picked up a set of Motorcraft from the dealer “part SP-594” and I noticed this thread and basically the NGK plugs are the ones most recommended. My question is about the temperature range, what is the benefit of running one step colder? This is something I have never been concerned with and just wanted to know if a step colder is better than what Ford has spec for the vehicle. I have a Tune but am currently running stock to help MPG, I have a VERY HEAVY FOOT with the tune on. If anyone could answer this I would be greatly appreciative…. Wouldn’t need a long explanation, just a short to the point type explanation please. Thank you in advance
Hotter or colder has to do with the average expected temperature of the plug. It doesn't have anything to do with spark energy so it won't have any impact on MPG. A plug should be hot enough to burn off deposits and cold enough so as to not burn up the electrodes, insulators or cause detonation. Some prefer a colder plug in a high performance vehicle, but practically speaking if they're not causing detonation or they aren't burning electrodes the stock setup is absolutely fine.
Virginia
TMac, thank you for the info, well written and just what I was looking for.
Minneapolis, MN, USA
Just installed the NGK Ruthenium HX spark plugs a few weeks back, great little upgrade so far. The install isn't bad, the hardest ones are the back (towards the driver/passenger side) but if you take your time and have the righ tools it's a simple job.
If I could add a bit to my last post in this thread. Consider the engine as a "system". If you're running high ethanol blends, I would not be running colder plugs. The latent heat transfer of ethanol is higher than that of gasoline which lowers the heat range of the plug, altering it's ability to burn off deposits. Another example of hot-rodding "lore" that might have made sense 40 years ago. I don't have any opinion on ruthenium vs copper vs platinum vs iridium but running "colder" plugs is not a performance enhancement.
I found straight copper plugs ran best in my CTSV. I believe all the precious metal tipped plugs do so only for longevity and do nothing for performance. Just my opinion of course.
Fort Lauderdale, FL, USA
What’s the torque spec for the spark plugs? Haven’t seen that mentioned in the forum
xrocket21
Augusta, ME
Yeah, I ripped mine up pretty good, but just sorta stuffed it back in.
CessnaDriver
Active Duty U.S. Air Force
Bossier City, LA 7111
If you felt compelled to replace it, I ordered one to see if the new one would slide in easily and it did. Downside is it cost about $50. My assumption was the age/heat in the engine caused it to dry rot and rip.
I ended up with one rip but decided to take UNBROKEN'S advice and not re-install it. I'll be back in there to swap plugs in the future and like the idea of removing heat from the area.
xrocket21
Augusta, ME
Thanks, but I think it is close enough as it is.
