Weird issues - Blind Spot, Cross Traffic, Power Windows, Mirror Fold, User/Seat Memory, etc
Hawaii
I've had a few weird issues today with my 2025 ST, and I'm wondering if someone here knows what it could be... Sorry in advance for the lengthy post.
I drove off this morning and noticed that my mirrors didn't unfold. I tried pressing the button to do it manually, but nothing happened. I then wanted to open the side window, so I could do it manually without getting out of the car, but the button for the power windows didn't respond. The rear windows did, but the front didn't. I then got hit with a blind spot & cross traffic fault in my dash, and when I went into the settings on my display to see what the setting was for the mirrors, but it was made unavailable. I could see it was on (blue switch thingie), but it was slightly darker than normal, and unable to select to turn off. I then started to toy a bit around to see what else wasn't working, and found that the user selector (the three buttons in the door) were unresponsive as well (though, about 30 minutes later it suddenly switched to another user without me asking for it at that time, so I'm guessing a delayed response?). Eventually, since I was about to run late, I got out of the car, manually unfolded the mirrors and drove off.
A few hours later, I got back into my car, and all issues were seemingly gone. However, another few hours, after about 30 minutes, I suddenly noticed the blind spot & cross traffic fault showing again, and this time nothing on the passenger side appeared to be working. For example, my (front) side window opened, but not the passenger side (weirdly enough, while I couldn't make it work from the driver's side, the passenger side button in the door did seem to work). Pressing the mirror fold button would work on my side, but not the passenger side. The user selection also didn't work again. When locking the car, the mirrors didn't fold automatically. However, when I just went to check on my car, the issues seemed gone again (but who knows for how long).
When I first got my car, I did do some coding, but nothing spectacular. Just the disabling of the horn when you get out of the car with the engine running, and I changed the DLRs from white to orange, for example. Other things that are attached to the electrical system are a dashcam with an external battery, installed shortly after getting my car back in October. And I installed the 4D Tech auto-start-stop eliminator about a month ago. I know someone else said on these forums they had issues with the 4D Tech eliminator, but I would think that if this eliminator (or the dashcam, or the coding, for that matter) was the cause, the issues would've been showing much earlier, and not about a month after installing? (though, if it is the eliminator, I should be able to return it before the end of the month, so suppose I need to find out quickly lol)
Does anyone have any idea what this could be?
Edit: I forgot to mention, the car had its last OTA update (TCU-25.2.8.5) on Jan 17, not sure the update has anything to do with it?
Combatvet
I've had similar gremlins in my '25, I think it's the BCM and that's why there is an open recall.
S
Hawaii
Thanks! That gave me something to look for... I just found this thread, and some of the symptoms there are similar as what I'm experiencing. Odd thing, though, is that I looked up the recall, but my car doesn't seem to be part of it. The Fordpass says I only have the windshield recall open. Ugh... not too happy about this :S
Combatvet
If you have a '25 I believe the recall affects all model year 25.
S
Hawaii
They say it is the cars produced up to June 6, 2025 (see also here: https://static.nhtsa.gov/odi/rcl/2025/RCLRPT-25V543-5627.pdf). Per the window sticker, my car was produced on or around August 5, 2025. I also cannot find any open recalls other than the windshield issue for my car. If it falls under warranty, then this doesn't really matter, but still :S
S
Hawaii
Since I had issues again this morning, I figured to remove the start-stop eliminator from 4D tech. The car seems to be fine again now. Unfortunately, it was also fine yesterday after a few hours, only to act up again a bit later. I guess I'll leave the elminator off for the day to see if the issues come back or not. If not, then the eliminator is going back, since I have until the end of the month.
Combatvet
I have the same module, and have yet to experience any issues from the device.
S
Hawaii
Yeah, it seems several people have the 4D Tech one without issues, I may just have a bad one. I'm not sure what it is. Either way, after I took it off, it seemed like my car was normal again. An hour later, I put it back on, to see what would happen, and the issues came back almost instantly. Took it off, and the issues were gone again. At this point I'm pretty certain it is the start-stop eliminator from 4D. I think I'm going to return it, and get the one from that other company that I saw mentioned on the boards.
Chairborne Ranger
My 2025 ST is a bone stock Build 1 vehicle and I am waiting for the new BCM to arrive to address the recall. I've got ~7,500 miles and have experienced none of the known symptoms for a faulty BCM as yet. The dealership called me this morning and told me the part should be here end of the week. Good luck getting your ST sorted out.
S
Hawaii
Thanks :) It looks like my car is acting normal again. It hasn't done anything weird since I took the auto-start-stop eliminator off, so I really do think it was the cause of it all. I'm considering getting one from a different company now, but I kind of wish I could've just done it through coding as I did with my previous cars. I really don't like that "feature" lol
