Adaptive Headlights question
Atlanta
2026 Ford Explorer ST
Do the 2026 ST's have them or were these also removed by Ford?
Massachusetts
2023 ST
Listed as only for the Platinum trim
I
Atlanta
Man what a bummer a nice feature I liked with my 2020 platinum. Going with a 2026 ST to keep the bigger engine. No idea why they removed v6 from plat line.
No STs ever came with them. Only Platinums.
I
Atlanta
Ok, guess I'll survive.
Gulf Breeze, FL
26 Explorer ST, 21 Bronco, 24 Ranger Raptor
I'm not sure if this feature is actually labeled as "adaptive headlamps" but our 2026 ST has a feature same as my 24 Ranger Raptor. If the fog lamps are NOT on while driving at night... when turning, the appropriate fog lamp will activate and light the area into the area being turned. Example... when turning left, the left fog lamp shines into the curve. Same if turning right. If the fog lamps are already activated, it won't matter as the area being lit is already significantly wider on both sides. When we purchased the vehicle the salesman said the Explorer ST was not enabled with that feature, but I noticed it the first time I drove it at night.
Massachusetts
2023 ST
That’s can actually be enabled/disabled via Forscan, even for the ‘20-24s. I think it’s called “cornering lighting” or something like that.
The Platnium Adaptive headlights themselves actually move to adjust based on road conditions
https://www.langladeford.net/blog/2...r-introduces-adaptive-led-lighting-system.htm
That's a feature I had on my last 2 MKZ's and honestly don't miss it. It was so gimmicky! I do miss the adaptive suspension!
I
Atlanta
Massachusetts
2023 ST
So will it be activated already on my '26?
I believe it is on by default in 25+ but can't say i've ever noticed it on any 25+ST i've seen on the road. I do not know if the line of code that would turn it off has been identified for 25+ yet
2025+ Ford Explorer Spreadsheet now available! | Explorer ST Forum
On the 20-24, no trim level has it activated from the factory. It's a pre-configured menu item in ForScan those years. It's in the BCM listed as "Fog lights as cornering lights"
That has to do with the fog lights. If you’re Turing right, right fog light turns out automatically, vice versa for left. Not the same as adaptive headlights.
Massachusetts
2023 ST
Yes. I guess I wasn't clear that I was referring to the fog lights operating as cornering lights. But like you said, totally different than adaptive
