Oily oil pan
K8G_BLK
Montreal
I did my first oil change since buying my 21 with 54,000 miles (bought last November) yesterday and noticed the oil pan was quite...oily. I didn't notice at the time, but looking at the pictures now, could the drain plug not have been tightened properly have caused this? It should be turned all the way to the tabs, right? The oil level was fine on the dipstick. I'm thinking I should just clean it and see if it get oily again now that I know the drain plug is back on properly.
Also, my used oil smelled like gas, a lot. Is that normal?
e1b608e761897bd95da36c246102a65e.jpg 69e026f37d7085348502bcc2e6514c9c.jpg ff0910a2c82062017e859e45a4bba0ef.jpg
LocoEngineer
*Shopping
Someone please correct me if I'm wrong, but I was under the impression that Ford plastic drain plugs are one time use, meaning a new one should be installed when doing an oil change.
As far as gas in oil smell, how long was the previous oil used? Excessive idling, short drives? Both can lead to the oil not getting hot enough to burn away moisture and fuel.
KCM
Nebraska
I would say yes that the plug is not fully screwed in. There is a definite stop when it is fully screwed into the pan, and you will feel a slight snap when you unscrew it. I screw mine in by hand but have to use pliers to get it loosened. As for one time use, I would say no. They are pretty durable and I have changed the oil in my Fusion a half dozen times with no issues with the original plug. I do keep a spare on hand just in case a tab breaks off. Previous owner installed a quick change drain plug in my Explorer and am due for my first change soon.
My Fusion does have a slight bit of leakage at the plug whenever I change oil, but not enough to get the pan wet other than around the plug. Since yours is not fully screwed in, maybe that is what happened. The plug has a single o-ring to seal, so may not be fully seated.
Farmers Branch, TX
I'd degrease/clean the area thoroughly and check on it in a 1,000 miles or so. Could just be residue from draining the oil and leaving a drop or two on the pan at the drain hole. Over time that still will drip and migrate everywhere. Also keep an eye on the front axle for leaks.
K8G_BLK
K8G_BLK
Montreal
Thanks all! I'm not too worried since the oil level was good, but I will clean it and keep an eye on it.
I've used the same drain plug for the last 2 years.
21 ST
drain plugs are required to be replaced every oil change unless you have a UPR drain plug
I've had no issue with mine. I don't go to the dealer for changes.
21 ST
well based on the photos it looks like you have a issue now, i too don't go to the dealer for oil changes, but you can purchase the drain plugs online or like i said get a UPR plug and never worry about it again. :cool:
I have zero issues not sure what you are talking about. lol
If you have not had the FADA oil leak fixed, then this oil leak is exactly that until proven otherwise.
See:
https://www.explorerst.org/threads/leaking-oil.5533/
This leak will affect ALL 2020 and 2021s that have the defective o-ring on the inboard side of the FADA.
Massachusetts
2023 ST
Mine was leaking on my '23 as well. Had it repaired under warranty.
Noticed it during an oil change where I thought I had just gotten a bit sloppy the last time around. Nope.
Massachusetts
2023 ST
FYi all, there is a new drain plug now
Features 2 O-rings, and a longer threaded portion so you can open it halfway and drain in a more controlled manner.
I've been doing 2-3 oil changes before getting a new plug on my Fords, but did pick one up to try next time around on the ST. Part number ML3Z-6730-B
2-3 Oil changes before replacing your drain plug - WHY? I've NEVER replaced a drain plug in my 2018 Fusion Sport (brand new in 2018 to today) that uses this same drain plug, or in my 2018 Explorer ST, or in my 25' Explorer ST. If you need a place to spend $ I will send you my bank routing # and account # so you can place it there. At the very wost case, I could see someone replacing the o-ring as a just in case measure, or if it has damaged, but that is it.
Massachusetts
2023 ST
Because personal preference. I know folks go long-term on their plugs. I just have a strong dislike for fluid leaks, so I change them out after a bit. Any sort of seepage due to o-ring compression set would irk me.
I did look into changing the o-ring over. It’s a #208 O-ring. It’s probably FKN or HBNR material, but I just don’t feel like being the test pilot to figure that out .
I've never once had dripping or seepage around or from the plug - NEVER, and Ford's been using this plug for many years.
I'll get you my routing and bank account number :ROFLMAO::ROFLMAO::ROFLMAO:.
