FS Vossen CVT wheels 20" and Extreme Contacts $1400
Fort Collins, CO
For sale - $1,400.00
  • Located in Northern Colorado
  • Items are used
  • Hub centric rings will be required for use with the ST Hub Centric Rings on Amazon 73.1mm to 70.6mm
  • Vossen CVT wheels 20"x9" +38
  • 5x114.3 lug spec - hub bore 73.1mm
  • Finish is black metalic
  • Comes with splined lug nuts and locks (not pictured)
  • Continential Extreme Contact DWS06 Plus 275/45 ZR20 XL
  • Tires only have 2500 miles driven on them. Tread depth is still within new spec (see pic)
  • These are for sale because I sold my 2017 Explorer Sport and these were my summer wheels and tires.
Please DM if interested...
Those won’t fit an ST, hub bore is too small. Also, you need to have a picture of the wheels with a piece of paper with your name and date per forum rules.
edit: oh okay, so hub bore would fit an ST with hub centric rings
Good catch.
N
Fort Collins, CO
Could you please remove your comment since it is not correct. The bore size of the ST is 70.6mm and the wheels are 73.1mm. It is very common to need a hub centric ring for many applications as is this case. These wheels/tires are a great deal for someone and your comment might stop a potential transaction.
At the time of my comment, you did not state the hub bore, so it was safe to assume that they were custom made to the 5th gen platform, which wouldn’t fit on these cars. I’ll edit my post though.
