'26 ST New Guy
ManInTheBox
CA Gold Coast
Glad I found this place!
I purchased my '26 ST late last month. I settled on this one because of 1: The color. The Carbonized Grey is sharp looking. 2: Second row bench seat. Wanted a functional adult sized 3rd seat in the second row since I won't regularly be utilizing the third row. 3: AWD. This thing feels planted, especially when exercising the full potential of the power plant.
I am not planning on any excessive modifications, but I did ditch the flimsy OE strut tower bar and replaced it with a Steeda unit. I am contemplating on replacing the exhaust with the Borla cat back Type S system. We will see.
Wishing you all a Blessed Christmas and peaceful New Year.
Congrats and welcome aboard.
Nice new ride. You do know that replacing the strut brace is only a cosmetic upgrade. It will not perform any more or less than the stock stamped steel brace.
Congrats on the new ride! Unfortunately, the strut bar does nothing on these cars. For the exhaust, Thermal is the best option. Borla is overpriced and doesn’t replace the crappy flex pipes.
Congrats!
Thermal or AWE are my choices for cat-back.
Rear sway bar is an excellent way to reduce roll and help provide a more neutral turn in.
J&L catch can is a good way to clean up intake air.
Even with a factory stock tune, I would still install a larger intercooler but I understand that job is not for everyone.
Drop the factory engine oil at 500 (leave in factory filter) then change every 5k (with filter changes). I am also changing both diffs early on as well, just did the rear diff and the fluid was a gray mess.
My 2 cents.
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
@ManInTheBox :
Welcome Aboard!!
A couple comments:
I do like your body color selection, it actually comes very close to being similar to the color of the wheels.
If you do decide to go with the Borla system, I'd be interested in hearing about your observations (before and after). I'm still turned against having ANY fake engine noise in the interior compartment.
Congrats!
My 2 cents.
What’s your reasoning for not replacing the oil filter on the first oil change?
The filter has capacity till the 5k change, swapping at 500 would not be necessary but no problem doing so.
On mine I did a 1k, 2.5k and then will do 5k intervals. I ran by 500 before I had a chance. Once I get past roughly 10k miles (when break in materials slow), I'll be running FRAM Synthetic Endurance (FE11955) filters and replacing every other change running 10k on each filter as they have good capacity and even at 10k I do not expect an effect on oil pressure delta.
Oil filters are cheap enough it’s best to just replace the with every oil change.
