22 ST Drone Sound During Deceleration
Stretch D
Tennessee
Traded my 17 ST for a 22 with 15k miles about 5 weeks ago. During my first week with it I noticed an intermittent drone sound coming from what sounds like the mid to rear passenger area. I only hear the sound during deceleration and sometimes coasting. It’s not a constant drone and so far I’ve not heard it during acceleration.
Dealer has had it twice. First they replaced the front rotors and pads even after I said the sound is not up front. Second time I took the tech for a ride so he could hear it. They then proceeded to check trans and motor mounts and listed to the front again. They basically said they couldn’t find the noise and if it got louder bring it back. Going back next week to insist they check the rear.
Spoke with service manager today and asked him to change the differential fluid and check the bearings and axles. He said he couldn’t just “tear into the car” unless they could pinpoint the noise. Said Ford wouldn’t let them. I find this to be pretty ridiculous. What’s the point of my warranty and extended warranty plan?
Any advice on the drone sound? Any tips on how to deal with a service department that apparently doesn’t want to dive into an issue? Do I get corporate involved or request a FSE?
Clearly they can tear into your vehicle without pinpointing the exact issue because they already have. It just hasn't worked out in their favor so far. By them doing this, they have acknowledged an abnormal issue. Its now on them to find it and RESOLVE it. You have the service write ups so there's no denying it. I suggest you have another conversation with the Service Manager to remind them of what I just wrote!
We all need to know when we've dug a hole too deep and when to quit digging. Since this is the dealerships hole they won't be allowed to stop digging until the real issue is found and fixed!
St. Louis
Caster's first sentence is perfection.
He destroyed their logic, use this to your advantage.
Stretch D
Stretch D
Tennessee
I can confirm that the drone noise does not occur if the vehicle is in neutral.
You have any mods?
Stretch D
Stretch D
Tennessee
No modes, completely stock. I’ve got Thermal 3” in the box waiting to go on, but not until this is resolved.
Wisconsin
I also have a 22 ST that I just purchased with 57K. My issue is a vibration when decelerating off the throttle. It’s a wave of sound/vibration. I just had the rear driveshaft replaced under warranty and it helped a little, but not fixed. It feels like exhaust, but it’s hard to pinpoint. A shift to neutral and it goes away. I checked the flex pipes and there is a very small tear in the chicken wire on the top of drivers side section. The tinfoil is still intact. I chose chicken wire and tinfoil because this is joke engineering. I don’t believe this the issue though. Maybe other broken exhaust parts I can’t visibly see?? It goes into the dealer again after the holidays. I’m hoping I didn’t buy someone else’s POS.
When is the last time you had an alignment?
Wisconsin
I’m not sure when the last alignment was. I’ve had the vehicle 4 months. This issue is either more drivetrain problems or an exhaust system problem. It’s getting worse by the day. Now when I shift from reverse to drive it jumps into gear. Low speed driving I’m getting abrupt upshifts in the lower gears (normal drive mode). Could be transmission / torque converter problem? Probably multiple issues. Good thing I have an extended warranty. I’ve never been so hard sold by a dealer for an extended warranty. They know these new vehicles are poorly engineered junk.
You mentioned vibrations and a bad alignment can cause that. Def worth checking soon to see if it's a torque converter problem. I'd also ask them to check the Cv axles.
Wisconsin
Agreed. Back to the dealer on the 6th and I’ll be pushing for a good look at everything. Thanks for the input
Stretch D
Stretch D
Tennessee
Alright gang, took this back to the dealer yesterday and it seems like they just don’t want to put any real effort into the diagnosis and potential fix. I let them know that the noise is not present while decelerating or coasting in neutral. The service manager told me that they inspected the drive train and couldn’t find any problems. He said the noise seems to be coming from the exhaust. This could be true given all the issues others have reported, especially with the flex pipes. Unfortunately, I had already spilled the beans to the manager that I was waiting to install my Thermal exhaust. Thus, they didn’t even try to change out anything on my current one. I have an appointment at another dealer in a few weeks. Just trying to decide if I wait and let them try to pinpoint the issue or just put the Thermal on while I’m off for the holidays.
Stretch D
Stretch D
Tennessee
After the dealership said my annoying drone sound on deceleration was coming from my exhaust I decided to go ahead and change out to the Thermal 3” I’d been waiting to install. Got everything buttoned up, added a Steeda anti-sway bar and hit the road. Car sounds amazing. Drone sound is now gone. Mission accomplished.
Wisconsin
That’s great! Thanks for sharing this update. I believe my issue is also exhaust. Please let me know what system you went with. This is most likely in my future.
Stretch D
Stretch D
Tennessee
I went with the Thermal R&D 3” cat-back. Loving it so far. Assembly with a pal was pretty straightforward and we managed to get the tips dialed in and even without much trouble. Sounds like a proper sports car.
Wisconsin
That’s so cool. Thank you and happy New Year with new pipes!
